Question about Garmin GPS
My Garmin Nuvi 350 sound not working - Garmin GPS
  • jsmedina Aug 11, 2008
    I am having the same issue with my Nuvi 350. I have all the sound settings correct, but nothing comes out. Any help would be appreciated.
  • blondieandag Sep 25, 2008
    sound stopped suddenly. tries to talk or make noise but can not understand
After adding 2009 European maps to my American maps Nuvi 350, I lost all voice navigation. I still heard the beep when I touched the screen, but no speech during navigation. I fixed it my running webupdater from garmin.com and updated the American English voices. Several of the languages have updates. Everything works fine now.
Posted on Mar 26, 2009
I had this problem with the 760. Solved by going to settings>language and discovering I had no choice for "voice". I pressed that selection and picked american english and my problem was solved. Garmin support said sometimes the program gets corrupted and that choice needs to be made again.
Posted on Jul 14, 2008
SOURCE: Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Posted on Dec 01, 2007
SOURCE: garmin nuvi 350
Heres what to do:
- Connect to computer using USB cable
- Flip up antenna and hit reset button.
- The unit should power up.
- Then put unit on wall charge to get a full charge.
That should do it if not call 1-800 800 1020.
Posted on Jan 07, 2008
I had the same dismountingproblems with a 360, but i found the solution. When you look behind de GPS-unit at the top of the case there are two little screws hidden. You have to dismount the GPS first to get to those screws. To dismount the GPS, open this unit with the two visible torcscrews. Open the GPS with little force and turn the cap clockwise and it will come loose. Look to the left into the plactic case where the GPS antenne is found. Then put a very small screwdriver in the shaft case (on the leftside you see a little whole 4 x 1 mm). If you put a little pressure on the screwdrive while moving it to the right you will feel a spring. Its working like a springconnection between a watch and a watchstrap. When you dismount the GPS look out for damaging the electrical connection. Then you can dismount the torcscrews and the maincase. When you open the case you 1 screw in the middle in the circuitboard. be very careful everything is very small.
Posted on Jan 08, 2008
sharcnet
  • 2130 Answers
SOURCE: nuvi 350 on off problems
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and I'll be posting a step-by-step procedure on how to fix this and prevent it from happening again.
I must point out however, that in order to make this repair, you will need to have skills in dissassembly and soldering.
Also, please only attempt this procedure if your unit is out of warranty.
If you would like for me to repair your GPS, please email me at KS3R at sharc dot net.
- Jim
Posted on Jun 25, 2008
dacust
SOURCE: Garmin nuvi 350 battery replacement
I can't do it for you, but I have done it myself. See the instructions on my webpage at www.dacust.com/nuvi350/index.html. Pictures and everything, along with where I got my battery and the part number, etc. Warning, there are many opportunities to damage your unit doing this. Not for the novice.
-dan
Posted on Jun 07, 2009
I need owners manual for my Garmin nuvi 350 NA. I
Connect your Nuvi 350 to computer with USB and look in Garmin folder for owners manual. It should be in the Nuvi's internal memory in PDF format.
Other: Go to www.garmin.com/products/nuvi and click Manuals link to download to computer.
Feb 14, 2010 | Garmin Nuvi 350 Car GPS Receiver
GPS - Garmin Nuvi 350 has mind of its own
Reset behind Antenna, press this in
and update it at Garmin
Should be good.
Regards
Ric.
May 16, 2009 | Garmin nuvi 350 GPS Receiver
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
The voice stopped working on my Garmin Nuvi 350 in mid sentence
what has happened? my etrex said low batteries. I changed batteries. now all I get is searching for sattellites? can anyone help?
Mar 30, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin 350 no sound
Please read this article I wrote on this problem.
http://www.fixya.com/support/r1091233-no_sound_or_garbled_sound_garmin_nuvi
Taking apart the Nuvi requires the right tools. There are delicate flex cables for the LCD, touchscreen & antenna inside. They can be easily damaged if your not careful.
Having worked on Nuvi's, I have never found a loose wire for the speaker. It's possible, but not probable. More likely you have a intermittant voice coil. Please read my article to further diagnose your Nuvi problem.
- Jim
Oct 02, 2008 | Garmin 12CX GPS Receiver
Garmins Nuvi 350 - voice interactive lost
I have the same problem with my Nuvi 350. It's only about 2 months old and the sound went. I turned it on the other day to use it and the sound did not sound right, it sounded like the speaker was blown. I turned it off and turned it back on and that was it, the sound was gone. I did everything possible and can't get the sound to come back. I called Garmin and now I have to send it in for repair. I looked around the web and noticed that Garmins have big issues with the sound going on the units. I hope they fix that issue.
Jul 28, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 350
sounds like you erased the software from the nuvi in some way. I think you'll need to ship it to garmin. No SD cards plugged in?
May 17, 2008 | Garmin nuvi 350 GPS Receiver
My Garmin nuvi 350, North America, will not show picture.
Has your problem been solved? If you need more information, I will be happy to try to assist you.
Jan 10, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
705 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
