Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 Carriage jam error - can I remove the covers
I recently moved and just unpacked my HP7410 - it's been in storage for a few months... I get the carriage jam messsage... I open the cover to address the problem, and find that a mouse has built a nest in that area!?! Any suggestions on how to get better access to the area under on the right side so that I can do a more thurough cleaning??
>try to turn printer off and unplug the power cord
>try to open carriage access door
>try to move the carriage left to right if it freely moves then try
positioning the carriage to the center portion
>once thats done. try to plug the power back and turn on
Posted on Jul 03, 2008
Carriage jam error message
Open up the printer cover and clean the timing strip with alcohol (That is that little long strip that goes all the printer long from left to right and passes behind the carriage)
Nov 29, 2015 | HP PSC 2355 All-In-One InkJet Printer
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
During startup the drive belt slips and gives an error
Open the printer's door and look for the print carriage. It's the platform that moves back and forth over the paper, probably where you put new cartridges. Unplug the printer, and check this belt and its pulleys to see if it's either broken or possibly covered in ink. The drive belt will be black and have gear teeth on it. If you see a metal or plastic ribbon, that's more likely the encoder that let's the printer's computer read the position of the carriage. See if you can nudge the carriage and make it move a little; it may simply be jammed. Check the carriage's moving path and make sure it's not obstructed. Any other problems would probably best be handled by Epson.
Feb 27, 2010 | Epson Stylus R380 InkJet Photo Printer
Carriase jam
How old is this device?
Turn the power off, then back on. Do you get the error straight away?
If so, open the cover and check for obstruction near the printheads.
If no obvious blockage, the power off / on again and when the carriage starts to move, pull out the power lead to stop the carriage moving.
Now attempt to gently move the carriage by hand.
If it moves with a fair bit of resistance, then try a small amount of lubricant on the printhead carriage rail.
Close the covers and power up the device.... Good luck.
Dec 06, 2009 | HP PSC 1610v All-in-One Printer
Carriage jam messsage
Please follow the steps mentioned in this link below:
HP Officejet 6210: Carriage Jam
Jun 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper jam
Solution
Step one: Remove any lose paperRemove any lose paper from the paper tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back of the product
  1. Remove the paper from the paper tray.
  2. Press the power button (c00636182.gif ) to turn off the product.
  3. Disconnect the product power cord from the electrical outlet.
  4. Remove the rear access door. Press the handle to the right, and then pull out the door.
  5. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  6. Replace the rear access door.
  7. Load paper in the paper tray.
  8. Reconnect the product power cord to the electrical outlet.
  9. Press the power button (c00636182.gif ) to turn on the product.
  10. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step three: Open the top cover and clear the jamIf the paper jam cannot be removed from the back of the product, try to remove it from the front.
  4. Raise the product cover, remove the paper jam from the front of the product, and then lower the cover. CAUTION: Remove the paper jam carefully because it is possible to damage the printer when removing paper from the front.
  5. Load paper in the paper tray.
  6. Reconnect the product power cord to the electrical outlet.
  7. Press the power button (c00636182.gif ) to turn on the product.
  8. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Step four: Make sure that the carriage can move freely
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Raise the cover and try to move the carriage from side to side by hand. 1 - Carriage holding ink cartridges
  4. If the carriage does not move, the product needs to be serviced. If the carriage does move, proceed to the next step.
  5. Make sure that the ink cartridges are locked into the carriage and have not come loose. Make sure that there are no obstructions under or around the carriage to prevent it from moving.
  6. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and to the right.
  7. Close the product cover and reconnect the power cord to the back of the product.
  8. Press the power button (c00636182.gif ) to turn the product on.
  9. Try to print. If the product prints successfully, the issue is resolved. If it does not, proceed to the next step.
Oct 22, 2008 | HP Office Equipment & Supplies
HP OfficeJet 7410 All-In-One InkJet Printer Logo
315 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
