Question about Olympus FE-180 Digital Camera
Lens keeps moving in and out, plus, the screen is blurry
When I turn my camera on, the lens goes crazy. And when I look at the screen, it's blurry and the lens is zooming in and out. The batteries are charged and I can view the pictures. But when I take pictures, it turns out blurry too. What do I do>
  • 3 more comments
  • Anonymous Jul 03, 2008
    Nikon Coolpix S600, same problem
  • gazinbali Dec 22, 2008
    Yes I have the exact same problem.. i have tried using  Alkaline batteries rather than the rechargables,  this worked ok on only 1 occasion. The problem remains.. any ideas?
    As far as weatherproof goes.. this camera has had the problem for several months.. I dont think the weather matters.. its never been in water.. or even got damp.. so ??
    Plz e mail garyplaton@yahoo.com if you find an answer someplace. Thanx
  • Anonymous Apr 03, 2009
    I wish someone would actually be helpful with this.
  • Anonymous May 03, 2009
    "Lens keeps moving in and out, plus, the screen is blurry"
  • Montani Sep 08, 2012
    Set the camera back to factory default options and the try it. A wrong lens program setting can cause a similar set of symptoms.r
    Sergeant:
    Champion:
  • 417 Answers
FAULTY OR ITS NOT WEATHER PROOF
Posted on Jul 03, 2008
Why a blurry screen and LCD?
Possible causes:
  • focusing - out of focus (is the lens moving freely?)
  • dirty glass - clean the front of the lens.
Oct 03, 2015 | Canon PowerShot SD1200 IS / Digital IXUS...
When I turn camera on lens error 111 shows up on screen and goes right off and lens does not come out
Make sure all the moving parts of the lens are free to move. If you dropped the camera or spilled something sticky on the lens part, it may be stuck and the camera cannot turn on.
Try this at you own risk:
1. Try jiggling the lens with your fingers while turning on the camera, helping it to pull out.
2. If there is something sticky keeping the lens from opening, try to use a warm damp cloth to dissolve it.
3. If nothing works, bring it to a repair center. You may also try the solutions provided in this other fixya article.
Mar 23, 2011 | Cameras
I have a Casio Exilim Zoom EX-Z80 Digital Camera. And my promblem is that once i zoom out everything is blurry. The whole picture is blurry but once I zoom out it is a bit better but not as much. I need...
Try cleaning the lens gently with a lens cloth or maybe a damp paper towel? Other than that - you may have something stuck in your lens that is making everything blurry when you zooom in...or the lens may need to be replaced to be fully functional. Do you notice any blurry spots when you zoom out that get bigger when you zoom in? If so something may be stuck in your lens. Good luck!
Jun 30, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Have blurry image - how do you fix it- Logitech Quickcam for Notebook
On the camera, the plastic around the lens rotates, that is used for focus. Open a video feed from the camera and adjust it until the image is clear. The lens might also need to be cleaned if it has got dirty, use a qtip with water or alcohol to clean the lens on the outside.
Dec 15, 2009 | Logitech Webcam
Blurry images
Sounds like a lens problem. If you've ever let the camera "auto turn-off" as a power-saving measure, any button pushed will turn it back on...even if it's in a case or your pocket. This puts strain on the lens as it tries to come out...result....lens problems.
Nov 13, 2009 | Panasonic DMC-TZ4 Digital Camera
Ok so i am turning on my camera (an Fe-340) and the lens go in two or three times then when the screen finally does come on it is blurry and way out of focus, also when i attempt to adjust the zoom the...
It may be something more serious, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Olympus FE-340 Digital Camera
Olympus FE-340 camera i turn on the power the lens goes in and out 2 or 3 times and the view is blurry in the view finder. The zoom feature has no effect when pushed to the wide setting and will turn off...
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Aug 10, 2009 | Olympus FE-340 Digital Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Jul 02, 2009 | Olympus FE-280 Digital Camera
Olympus FE-180 Digital Camera Logo
580 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
