Question about Panasonic PT-50LCX63 50" Rear Projection Television
Where can i buy the ballast repair kit for the PT-50LC13 tv?
  • 20 Answers
Www.encompassparts.com i hope this help
Posted on Feb 18, 2009
  • 19 Answers
Order Ballast Repair Kit from Panasonic, Part no. LSUC0022, ~$22.
http://www.pstc.panasonic.com/Epartr/PartsListChoice.asp
Posted on Aug 07, 2008
Try these guys out
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150273671347&ssPageName=STRK:MEWA:IT&ih=005
Posted on Aug 02, 2008
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
Trouble with tv coming on to long and new bulb didn't work
Is the lamp light blinking twice every 5 seconds or once every 5. Once every 5 sec. lamp failure,...twice every 5 sec.. ballast or thermal fuse. The ballast is discontinued and must be rebuilt or purchased used,.....try Ebay. NO TV REPAIR SHOP IS GOING TO HAVE THE BALLAST! They may be prudent enough to check into and find the rebuild kit for the ballast. FYI a rebuilt ballast costs around $175.00 ,....the rebuild kit costs anywhere from $12.00-$55.00
Jan 06, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How do I replace the ballister?
DLP TVs use Ballast board it is what turns Lamp on! Take back off look for capacitors 1000uf16v if any of these are puffed up on top they are bad.Ballast board plugs in easy to replace,for good working board look up on ebay got one for 57.00 Good Luck with the repair.
Sep 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 won't turn on. Will blink green and make a chirp noise
It is the balister not the lamp. Very common problem that Panasonic will not address. Costs over $600 to repair. file a complaint with consumer affairs please.
http://www.consumeraffairs.com/php/a_report.php
Jul 03, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13
The ballast probably needs to be repaired. A repair kit #LSUC0022 is available from Panasonic.
Jul 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13
It could be the ballast that is bad. A bad ballast also shortens the Lamp life .
Jun 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
PT-50LC13
This model is notorious for a ballast kit needing repair if lamp doesn't fix. Need professional help, probably $300 ish
Jan 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LCX63 50" Rear Projection Television Logo
433 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
