Question about Car Audio & Video
No sound on after market radio
The stock radio is not infinity nor are the speakers.
  • 85 Answers
Did the radio have sound before the radio was put in?
Posted on Jul 03, 2008
  • 3 more comments
  • chad graves Jul 03, 2008
    check the relays under the hood for a name brand speaker relay. cant remember if all were labeled infinity or not. if you could give me the vin# it would be lots of help.
    any speakers in the dash?
    if it has the base system it is straight up wiring like any other car would be
    the easiest way to tell if highline is the connector on the speaker highline has a 6 pin connector and base has a 4 pin with 2 wires. the only thing in common with all the speakers on a base setup is the radio.
    is the blue wire on the radio connected? it will work normally with highline as long as its hooked up. unless there is a problem in the van its self relay, radio choke.
I have 2004 dodge ram1500 with infinity sound system hooked up kooertron jp816 no sound volume was up
Get rid of the amp. After market radios won't power the factory amp. A bit of wiring to speakers to do. All can be done at the amp plugs.
Jan 08, 2017 | Dodge Cars & Trucks
Stereo crackles
A little more detail. Do you mean speakers are crackling. Most likely blown the factory speakers. These are very cheaply made. And if you play music loud often they will blow easy. Is it completely stock system. If you relaced your stereo with an after market it may be the wrong ohms for the speakers or to much power and you need better quality speakes. If not coming in clearly make sure your antenna is tight and your wire harness are are connected securely. Let me know more details. Do you have infinity sound or not. Any after market components. Or completely stock.
May 02, 2013 | 2000 Dodge Ram 1500 Truck
1999 dodge grand caravan with The stock Chrysler/Infinity sound system
You can use the amps if your replacement speakers have the same or higher resistance as compared to the original speakers.
Sep 02, 2017 | 1999 Dodge Grand Caravan
Just removed stock front speakers from 2000 Jeep Grand Cherokee with premium sound. Speakers were working, but my son wanted new ones. Installed Infinity 9632cf speakers and we're barely getting any...
A lot of companies are using 2 ohm speakers for stock speakers. This means they are more efficient (sounds strange that a stock speaker is efficient). The stock amp may not be able to put enough power out for these to sound good. You may end up needing a new system.
Sep 01, 2011 | Infinity 9632CF 6" x 9" Coaxial Car...
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
Stock speakers with HK Business head unit. speakers sound lousy, any after market speakers you could recommend to replace stock?
Hello sharkdc0529,
I'm not familar with the HK Business head unit, and could not find such in an online search. I thought it might be "Harman-Kardon" but struck out again. Anyway, most stock speakers will sound lousy with an aftermarket head unit. Take a look at the typical factory speaker (top photo) and an Infinity aftermarket speaker (bottom photo) on this page. There's a world of difference in the materials and construction.
In addition to Infinity, I recommend Alpine, Kicker, and Rockford-Fosgate. You'll also find that Kenwood, Pioneer, and Sony make some excellent sounding speakers at very reasonable prices.
You'll need to know the size of the stock speakers and replace them with the same size. Also, be aware that most aftermarket speakers have larger baskets and magnets and will therefore have more "depth". Make sure you have ones that fit or that you have an appropriate adapter.
Hope this helps.
Sep 10, 2009 | Car Audio & Video
2001 dodge grand caravan radio
do a me special ,,,,rewire the speakers
Feb 26, 2009 | 2000 Dodge Caravan
Radio on but no sound
i have a 1994 eagle vision, with the premium sound system (infinity) and yes you do have a amp in your car if you have that sound system and its in the trunk of your car to the left while looking at your trunk from the back of the car :) also if you tryed putting in diffrent speakers other then stock thats your problem you have to rewire new speakers cant use old wiring because it goes threw the stock amp and for some reason the stock amp only works with the stock speakers :P
Oct 01, 2008 | 1995 Eagle Vision
Open Questions:
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
