Question about Epson Stylus CX4400 All-In-One InkJet Printer
Changing ink i'm having trouble changin the ink...
  • rob211 Oct 13, 2008
    Machine did not like new branded black cartridge, now it has accepted it the dialogue printed misses every 4th or 3rd line of text.
    Text misses every 3rd or 4th line, leaving blank
    Problem Solver:
  • 15 Answers
You need to clean the nozzle and there is a procedure from the printer properties menu on how to do this.
Posted on Oct 19, 2008
I have a Jaguar X-Type 2.5L and the check engine light is on as well as the other light on the board. It also says in the screen that the cruise is not available however It is functional. The problems are...
need to run a scan with a data stream-to diagnose--just pullin up codes doesnt doit--also are the fluids new and at correct level--if theyr dirty or old things are slower to work--clean the throttle body and idle air motor to stop stalling--chec for worn ignition components
Mar 28, 2012 | 2003 Jaguar X-Type
Whenever I change a channel on my Sky/Hd box the T.V changes to Freeview
Have you tried pressing the button that says 'sky' on top of the remote controle before changin chanel? it could be something as simple as that, if that fails id advise you to ring sky
hope this helps
Mar 03, 2011 | Sky Toys
Where is the out put sencor on a hyundai elantra 2000 and dose any one know wat my problem might be i just bought a new transmission and the car has trouble changin mostly wen speed is incressed and...
I am not for sure on your car, but my car has a TCM, a Transmission Control Module. I had the same problem but only at an increase in speed, not decrease. Just trying to help. Sorry it's not much.
Jan 13, 2011 | 2001 Hyundai Elantra
Do you have to take off the front to change the coolant hose
what a stupid idea,taking the front end off to change a hose......the answer is YES.(you should see the work involved in changine a headlight on a beetle.)
Oct 02, 2010 | 1998 Audi A4
Is it worth the trouble changin an oil pump on a 1993 chevy silverado 5.7 or better to go with a short or long block?
Your better off going with a short block or long block assembly.
If the oil pump went out, then there is damaged done that will not be solved by simply changing the oil pump.
Nov 07, 2009 | 1995 Chevrolet Silverado 2500
Trouble codes - red and green light flashing alternately
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
810/820 http://www.mediafire.com/?m6ouftizois
Jan 11, 2009 | Epson Stylus Photo 820 InkJet Printer
Won't print after changine both cartridges
fix your cartirge again. also try with other cartridge
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Yahoo messenger and email cant login says id and password has been changed i dont remember changin it
If you really does not change your id and password, it is likely due to virus infection. Have you remembered someone chat you with a link ? One of my officemate experienced the same problem, his yahoo email password was changed due to a virus infection.
Sep 09, 2008 | Computers & Internet
Ink cartridges
lift little door above paper tray with power on and cartridges will advance to a place where you can get them out....you will see.
Sep 04, 2008 | HP Officejet 5510 All-In-One Thermal...
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
Epson Stylus CX4400 All-In-One InkJet Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
