Perhaps 1 battery is dead other is good motor is 24 volt horn is 12 volt
It sounds like the batteries have gone bad and need to be replaced. Very little power is needed to operate the horn, but much more is needed to make the motors work.
The batteries contain a gel that needs to have current run through it on
a regular basis (at least 8 hours once a week) or it will oxidize and solidify. If
you attach the charger, what will most likely happen is the green light
will either stay green or go to green after a very short time. When you
turn on the power chair, nothing happens. The charger will indicate the
batteries are full, but instead of being full of power, they are full of
crud. Your warranty will most likely not cover replacement as this is
due to customer neglect, but your insurance
may still cover the replacement batteries if you can wait for the process to go
through. Otherwise, you will need to replace the batteries on your own,
type U1, 24v 33 amp, approx. $125 each at Batteries Plus or Interstate Battery. Good luck!
