I cannot copy onto the disc drive. It keeps coming up with error message Optical drive device Locked. Can someone please help
  • starnick Jul 03, 2008
    Thanks for the advice only thing that it's not a laptop. It is a normal Acer PC Can you let me know if I can still do the same steps.
    Desperately need help.
  • 313 Answers
I will bet anything the computer you have is an Acer Laptop.
Try this:
1. Go to and download from the site 'elock'.
2. Install and run the program.
3. It will ask you for a password, type one in. (any - just write what you wrote down)
4. Then click on the items and lock them. (Yes I said lock them)
5. Then click on site you want to unlock and enter the password again.
6. All the sites that acer elock had locked will be unlock.
Posted on Jul 03, 2008
  • Hollyecho Montgomery
    Hollyecho Montgomery Jul 03, 2008
    Yes, same steps apply. Acer is known to have this problem.
Front panel on machine just reads ..disc not finalised.what does this mean please?
Are the discs ones that you created (burned), someone else burned, or commercial discs? The message of disc not finalized usually appears when you put a CD or DVD from one unit into anther without closing (finalizing) the disc. The finalization step doesn't matter if the disc is being moved between computers with compatible OS versions (for example: XP through Windows 7). However, any other device will need this procedure completed.
Take the disc back to the unit (computer or other burner) where the disc was burned. If the computer uses Windows, put the disc in the optical drive. Open My Computer (Computer) depending on the OS by double left-clicking on the icon on the desktop. Right click on the optical drive and select Close Session.
If you created the CD on another machine, check the details for that device.
Note: you should double-check that the format that you burned to disc is compatible with this CD player. Not all models support MP3 files. On my own older CD player, I had to burn WAV files without gaps in a Disc At Once format to get the discs to play without skips.
I hope this helps.
(if the discs were commercial discs or have been finalized, I would expect a different error. In that case, I'd suspect a tracking problem and a "No Disc" error.)
Jun 15, 2012 | Marantz Audio Players & Recorders
Hiya. how come certain files dont copy to my san disk cruzer slice? there comes a message saying 'type of file error' and it tells me to skip.please help me out as i need to back up some files.thaks
If you KNOW what file types these are (eg: .doc or .jpg) try making a copy of one, rename it to the appropriate file and see if that works
(example, you have a word file that is say.. me.doc. make a copy, call it me2.doc, delete the file extension (.doc) then rename it with the file extension again before saving it.. Sometimes this works.
If that does not work, try copying to a different usb disc or device, if it does work, you should reformat and check the san disc for potential future failing
Jan 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
'bad disc' error message comes up every time I
Your optical pickup drive lens is dirty or needs to be replaced.  Run a DVD disc cleaning kit through it and see if that helps.  If not, then you have to open this thing up and clean the lens with a bit of rubbing alcohol and then try.  If that don't work you can either kick it to the curb or replace the optical lens.
Nov 13, 2009 | GoVideo Go Video DVD/VCR Combo
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
Optical drive device locked
why have you made multiple useraccounts to ask this question?
Sep 06, 2008 | Computers & Internet
The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb...
Hello I have the same problem but no body do answers . Maby we change radio {panasonic or oder :-). The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb key along with music files in mp3 & W4ma types though we still can't seem to get the Tevion 5705 car radio to read the music from the usb key when inserted. We keep getting an 'Error 13' message, can someone please help . my email : Ladi
Aug 13, 2008 | Car Audio & Video
Drive E wont read media
You need to replace the optical drive as it is no longer working.
Jul 06, 2008 | Compaq Presario 5000 PC Desktop
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
