Question about Canon Cameras
I have a canon PowerShot SD200 Digital Elph and I was tinkering with it. I went into the "tools" section and selected "format memory card". When I did this all the images that I had saved seem to be lost. Are they or is there some way that I can retrieve the images?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Hi,jbeckenhauer! You can recover your lost images from your Canon PowerShot digital camera with a Canon Photo Recovery program: http://www.canon-photo-recovery.com/ Best wishes!
Posted on Mar 09, 2012
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off)and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
If you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/rescuepr...
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recovered your pictures to your PC safely!
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 03, 2008
I have a brand new canon powershot sd1400 and it says memory card error. Please help! One answer I saw was: Go to the menu screen, scroll over to the tools option, scroll down to format and format the...
You may try to install memory card into an external reader for a pc and try to format that way. Place card in camera and connect camera to computer via usb cable and try to format that way. I had a canon that the only way to read the card was when it was in the camera, if I tried to put memory card in an external reader it would not recognize the format. Canon does some wierd things with their stuff. Good luck and if this was helpful please vote. Thanks.
Feb 13, 2011 | Canon PowerShot SD1400 IS Digital ELPH...
Cant format new 4 mb memory card on PowerShot sd700 is digital elph
If you cannot format the memory card using the format function of the camera, please connect the camera to your computer and use the computer to access your memory card and format fromt the computer.
Alternatively you can also use a memory card reader and connect the memory card to your reader and connect it inturn to your computer and format it from the computer
Dec 25, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
The canon says "memory card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 12, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Can sd200 elph camera will not turn on battery is charged
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 09, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
Unable to download pics from Canon sd200 elph
It's probably not your camera. Microsoft updates frequently cause problems with our equipment. That's why pros use card readers and eliminate the headaches.
Jan 25, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Reformatting sd memory card for canon camera an 8gb card and it told me I coudn't print pictures on my HP photosmart 380 series printer unless I reformatted my memory card??
If your camera is indeed an SD200, am sorry to say an 8GB SDHC will not work in this camera. The camera will fail to recognize it, and will do this by giving various problems as you've run into. The overall problem is that the camera was designed before the SDHC format came out (SDHC cards although the exact same in appearance are different in format than standard SD cards). The largest size card that the SD200 will recognize is a 2GB standard SD card.
Jun 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Reformatting SanDisk for Canon s5is
y dont u format it on windows try card reader if nothing happens then ur card is faulty it seems like
Feb 23, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Cameras Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
