I have a Kenmore 54351 dehumidifier. The auto-off light started flashing and it would not run, so I cleaned the filter and it ran for an hour or so and then the auto-off light started flashing again. I looked at the filter again and it is very clean. Any suggestions? Thanks.
Comments:
Jul 07, 2008
- No responses yet, but I let it sit for a couple of days until I could look at it and I turned it back on (before I did anything) and for some reason it decided to work on it's own again.
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended...
(More)
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended period.
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running....
(More)
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running. Kenmore model 580.54351 35 pint Basement is wet and not sure if this model is for basement temps but it works the same in warmer temps.
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change...
(More)
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change the %. It just beeps. the bucket full light flashes even though the bucket is empty. I usually set it on 3 hrs on/off. Have tried powering on/off, etc. Coils not iced up.
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect...
(More)
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect water
