Question about SanDisk Sansa e250 MP3 Player
How can I fix my SanDisk?
My fiance bought a SanDisk Sansa two years ago. I am not sure which model it is but it looks like the e250. I can not turn it on no matter what I try. I sometimes get the blue light on the turny thing to go on but thats it. Nothing happens when I plug it in to the computer. I have tried many things to fix it but I have run out of options. I was wondering if you are able to help me. I know that he tried or did install a program or something so that it would work with a Linux system and then after that I don't know what he did or what happened. All I know it that I need some serious help to fix it. Thank you for your time.
Jenise
  • 8,596 Answers
You will need to reformat the player. When it was plugged into the computer with the different OS (Linux), it reformatted the player in a way so that it will be difficult to use on another OS.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 03, 2008
Hi ı am sevda from turkey,istanbul.ı bought a sansa e250 two years ago which ı can not open it.it always resets sothat ı cannot see the data files on my computer which...
First the Sansa has two mode of operation or, two different ways to hook to the computer. See my tip posted here MP3 player Problems. In this tip I tell you about this problem. See also other tips I have posted about Sandisk player >> MP3 player frozen. And MP3 player not recognized by computer. Among others. Please check these out as they contain info that will help you with this problem.
Feb 10, 2011 | SanDisk Sansa e250 MP3 Player
Please help.How do I put videos into my Sansa
ok try to use itunes software or windows media player software.
this may be user friendly for you.
Use itunes it is best
just add everything in the library then select synchronise to your mp3 player.
be sure to connect and your computer detect the mp3 player.
ok
cheers
uttam
Jan 13, 2010 | SanDisk Sansa e250 MP3 Player
I can hear music on my sansa e250 but i cant see the screen?
make sure you have headphones plugged in. Once your in the screen for music or radio turn the clear dial (that looks like a border but isn't) clockwise to turn the volume up.
Apr 10, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e250
Get the recovery tool from Sandisk Support downloads. Put it in a file you can easily find.
plug in the Sansa, once it turns on, hold the power button until it turns off then switch the hold switch at the top edge of the player to hold (showing orange) and then hold the "Record" button on the side until the player turns on with a black screen, saying it is in recovery mode.
Some people have said they had to hold both "Power" and "Record" to make it work.
Run the recovery tool software and you should be running again.
Jun 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa sandisk
LOOK AT THESE WEBSITE FORUMS...THEY ARE FOR THE SANDISK SANSA PLAYERS
http://forums.sandisk.com/sansa/search?submitted=true&q=E250
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Cracked screen
if you have a warranty in the store that you bought your sansa from you can change it or replace it. but if you don't have the warranty you just have to take it to a small store that fix the screens.
Feb 20, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 frozen
That happened to me. Take the battery out and then put it back in. Mine worked fine after that.
Nov 29, 2006 | SanDisk Sansa e250 MP3 Player
Problem when starting
Hello Devildeiss, Try to format the unit. Follow the steps 6 and 7 of the solution i presented here: http://www.fixya.com/support/t119082-sansa_e270_refresh_database Note that all data on your unit will be erased! But maybe that exterminate with your current problems. Good luck!!! Eduardo.
Oct 03, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
