Question about Polyview V17E 17" LCD Flat Panel Monitor
Polyview v17e - microphone?
Hi does my monitor have an inbuilt microphone?
Thanks
Matthew
    Problem Solver:
  • 9 Answers
G'day Matt,
No microphone. It has a line in socket to drive the stereo speakers.
cheers,
dave.
Posted on Nov 29, 2008
Does it have a builtin microphone
Yes this monitor has a built in speaker on it, here is the complete details about this monitor.<br /><a href="http://www.newegg.com/Product/Product.aspx?Item=N82E16824024506&amp;SortField=0&amp;SummaryType=0&amp;PageSize=10&amp;SelectedRating=-1&amp;VideoOnlyMark=False&amp;IsFeedbackTab=true#scrollFullInfo">http://www.newegg.com/Product/Product.aspx?Item=N82E16824024506&amp;SortField=0&amp;SummaryType=0&amp;PageSize=10&amp;SelectedRating=-1&amp;VideoOnlyMark=False&amp;IsFeedbackTab=true#scrollFullInfo</a><br /><br />
Aug 26, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E monitor looses power at irregular times
Check your power saver settings
Start - Control Panel - Power
May 08, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
When i start up my computer the screen is blank - its a polyview v17e. we manually must press menu on the monitor then move across to display settings and select analog - the screen then starts up? how do...
You may have to look at the setup menu to see if you can turn on 'AUTO SOURCE SELECT' and set to auto. You may have problem with the logic board that is why it cannot auto detect the DVI or VGA port automatically.
Mar 21, 2010 | Polyview V17E 17" LCD Flat Panel Monitor
No sound monitor speakers
hmm the monitor is connecting to the pc sound card ...and for that you have to have a sound driver installed...if you know what kinda pc you have its easy ..but if its a built one ..you gonna either look inside to see what is the sound card name ...or try to see if you have a previous sound driver installation .....if you did had sound or still have on the ear pieces you have to have on the monitor too..just see the volume ...and the cable connection ..if it has a separate one (3.2 jack )or it connects directly with a HD cable
Aug 03, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor goes blank , power light goes off.
Click start, then then control panel and click on the power management icon. When you see the screen, look at the power management "scheme" and pick the appropriate setting. I assume that what you are experiencing is what's known as "Power management" . In order to achieve an "Energy Star" rating, the computer must shut off various components to conserve power. If you don't want to have your monitor shut down, select never from the options in the Power Management screen. Thanks for using Fixya.com
Jan 27, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
I have problems with my LCD polyview
These monitors are plug and play compliant and should not require any drivers. If you are having video problems it may be the video card.
Apr 06, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E
Same as before this sounds very similar to the problem that I had with my polyview v396 19" . Its a power supply problem unclip the panel withdraw the power supply it plugs in on its own seperate board. Look for capacitors that bulge and replace them in fact replace them all on tha board not that hard. Replace them with the same rating voltage and micro fards. Cheaper than relacing the whole panel, hope this helps. :)
Dec 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Driver for Polyview V17E 17" LCD Flat Pane
if you are using windows and it just won't let you go on the other resolutions try checking the monitor settings in your control panel
Nov 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
No sound
if your monitor has speakers, and it should  built in; then you will see a separate lead with  green plug on the end of it which is to be located in the rear of your pc with the green marked socket.
If theres no lead, then there must be a connector on the rear of the monitor
Oct 22, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview V17E 17" LCD Flat Panel Monitor Logo
88 people viewed this question
Top Polyview Computers & Internet Experts
David Payne
David Payne
Are you a Polyview Computer and Internet Expert? Answer questions, earn points and help others
