Question about Fuji FinePix S2 Pro Digital Camera
Error message is F--
My S2 will be working just fine and then I turn it off and when I turn it back on the top display has a F-- on it. (which according to the book means "a non-CPU lens is attached or lens is not attached.) Sometimes I can just turn it off and back on and it is ready to go and other times it takes a while.
Other than turning it on and off I don't change anything (lens, batteries, etc). Do you need to clean the sensors on the camera and/or lens at any point in the life of the camera?
Well, it looks that FE message means that the camera is confused. I saw this message when I put a non-D lens and automatic TTL flash  (which does require D lens to measure a distance). Usually putting the camera (or flash in my case) into manual mode got rid of the error.
Posted on Jul 14, 2008
When my S2 IS is turned on, the lens moves out, a beeping sound occurs, but the viewfinder remains black except for the message E 18. The lens does not move back in when the off button is pressed.
The Error E18 is quite a havoc on these Canon cameras. Here is a blog with great info on it: E18 Blog
Do not force your lens back into place and don't try and jiggle it either, you will be further damaging other pieces.
This camera is very powerful and the repair is well worth it. Teleplan Camera Repair provides a quote online with the cost clearly displayed.
Aug 04, 2010 | Canon PowerShot S2 IS Digital Camera
Viewer turns off (black) when folded back against the camera.
When the big LCD is black the view finder will turn on, right?
You need to replace a new hinge unit. Here is similar solution
How to fix an intermittent display LCD on Canon PowerShot S5IS
Jun 26, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon S2 IS works fine except the display will not provide picture viewing capability when I turn the camera on for picture taking. It will display photos from the memory card. The viewer is black for...
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Jun 24, 2009 | Canon PowerShot S2 IS Digital Camera
Fuji finepix s2 pro
the lithium batteries power the flash and some of the metering. But if they drop below a certain power, the camera dies. The F33 error is probably the accidental movement of the aperture ring on the lense. If you get the error, check the aperture ring is set.
Aug 11, 2008 | Fuji FinePix S2 Pro Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
The Camera Fuji FinePix S2 Pro1 is not starting up
Generally, in indicator on the back display shows empty battery; sometimes after a short a message Err on a display
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
108 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
