Question about LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher not responding to "power"
Our LG dishwasher appears to be dead in the water. No response from unit at a call for power. Checked to make sure it was plugged in. Checked circuit breaker. Checked outlet, 124v. Checked first connect for power.
And this is where it is new territory.
  • 5 more comments
  • meghan nicol Nov 24, 2008
    My LG LDS5811ST has worked fine for two years, last week it will not power on. No lights to the control panel. Breaker is good, power is reaching the dishwasher. How can you test the latch to see it that is the problem rather than the control panel?
  • Anonymous Nov 30, 2008
    Our dishwasher is about 2 years old too. It also does not turn on. If we open it really far and then push the on button it sometimes turns on and we can get it to run a load. Once it starts it's fine. However, it doesn't always turn on or goes back off when the door is raised or shut. We had the geek squad come out and change the control panel-didn't work. He put the old panel back in. Now we are waiting for a wire harness to see if that works. This has been an almost 3 week process with best buy and it's getting frustrating!
  • eric787 Jan 02, 2009
    Almost exactly two years here too. Power to the unit tests OK. Door switches test OK. Dishwash will not power up so displays no error indicator in the display.
    Also almost exactly two years in service.
    Power to unit tests OK.
    Will not power up so no error display.
  • CHutchings Jan 12, 2009
    Same thing! I worked fine last Thursday. Friday? DOA. Mine is also about 2 years old.
  • petey666 Jan 13, 2009
  • Steve Papp Mar 10, 2013
    It is propubly the door switch, remove the door panel and sort the swith, see what is happening. If you are not familiar with electricity, please, DO NOT TAUCH IT.
Check the door switch. THis will kill all power to machine.
Posted on Jul 05, 2008
How do you replace the water level sensor?
Samsung Dishwasher Repair oE code_CRICKET in Water ...
? 3:23
Jun 22, 2014 - Uploaded by Mgionfriddo
Samsung Dishwasher failed less than a year old. ... Removedwater level sensor to inspect and found a dead cricket blocking the float inside of it. ... worst, it'll throw that error right after 2mins of power on, any ideas what to do next? .... Dishwasher HeaterReplacement - Samsung Dishwasher Repair (part ...
Dishwasher Water Fill Sensor Replacement - LG ... - YouTube
? 6:28
Jan 24, 2013 - Uploaded by
Dishwasher Water Fill Sensor Replacement - LG DishwasherRepair (part #6501DD2001A) ... instructions ...
Nov 24, 2015 | Dishwashers
Whirlpool quiet partners II normal light flashing
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
LG LD-2040WH Dishwasher problems: It appears the bottom spray arm of my dishwasher no longer rotates or sprays. I had to replace it several months ago and the new one has been fine until now. I removed it...
this dishwasher had many design flaws that generally cannot be fixed even with multiple service calls. lg has scrapped the design and replaced it with their "direct drive" line of dishwashers specifically to remedy the problems with stationary spray arms. my advice would be to replace the unit.
Sep 26, 2013 | Dishwashers
Dishwasher didn't drain - totally non-responsive panel
Hello , that wire is only a ground wire, it should be hooked up to the frame . The draining problem is the water pump not being powerful enough anymore to pull the water out. I think there are rebuild kits , but its not expensive to replace either. It would be a great saturday am project! Thanks , Quinn
Aug 21, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Won't drain, no power
replace water pump at the bottom of the unit costs about $40.00
Jul 09, 2009 | Dishwashers
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
706 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
