Question about GoVideo DV2150 DVD Player/VCR
Loss of color when watching dvds
There is no color except for black and green when watching dvds. The TV is fine when on cable, with full color.
  • 979 Answers
Uh oh, time for a shop visit as the chroma processor is not working properly....accordianman
Posted on Aug 03, 2008
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
Oct 04, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Red Color not working
Does this only show up in one connection IE: HD cable box, DVD player etc, If connected to a HD cable box a loss of red can mean a defective red component cable.
Aug 15, 2009 | Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
DVDs all play in Black & White
Could be because it is set to NTSC. Needs to be set to Pal.
Mar 27, 2009 | Panasonic Televison & Video
Dvd color is off
Depending on how it is configured to your TV it could be high contrast with the TV. One thing you might want to try is replacing the video cable if you have a spare. If you are using an RF modulator and watch DVDs on Channel 3, you might want to replace the coax line between the box and the TV set.
Jun 29, 2008 | Panasonic DVD-S35 DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Toshiba 57H81 Color Problem
sounds like your green tube is set to high.
take the front cover off and the plastic cover under that
you will see a black box about 6x6 with 6 controls one is for focus the other is for intensity
here a guide for sony but yours should be close.
Mar 14, 2008 | Toshiba 57H81 57" Rear Projection...
Color looks horrible when playing dvds. when watching tv, the color is fine. help!
U have to use a hdmi cable ok or red green blue coumpount cable ok that way get a better picture thx for using fix ya .
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
GoVideo DV2150 DVD Player/VCR Logo
88 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
