Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
IW811 Loud Noise During Fill Cycle.
G'day, After the initial part fill and short soak there is a loud squealing noise which to me sounds like a dry bearing in a pump. My question is how do I get into the washing machine to check out this noise? The back of the machine appears to be welded/crimped closed so as far as I can see the only way into the washer is through the top or bottom. Ideally I'd like to be able to put the machine on the fill cycle and have access to the innards at the same time but I don't think this is possible. Any suggestions?
Regards,
Jeff.
  • Anonymous Feb 01, 2009
    i was under the ipression that Fisher Paykal washers don't have belts.
  • jkeferl Feb 12, 2009
    I have the same problem. The squealing noise is VERY loud, and comes on and off during the cycle.
    I too am under the impression that my washer does not have any belts since it is direct drive...perhaps the previous person providing the "solution" is not familiar with F&P?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
SOUNDS LIKE THE BELT IS SLIPPING !
My advice is to call a trained tech.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
Frigidaire dishwasher model number FDB4050LHS1 making a loud squealing noise
Usually this is the drying time of the cycle. I would have a professional look into the blower assembly and heating elements of the unit.
Aug 25, 2012 | Dishwashers
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Kenmore dishwasher has loud noise during fill. If you let it go, the washer fills. Once filled, noise stops and wash cycle continues. Sounds like plumbing does when there is air in the pipes. Not a...
This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
Apr 19, 2009 | Kenmore Dishwashers
Very loud noise during initial fill cycle only
Try it in different temp settings and see if it makes noise in both hot and cold. It probably does it in hot or warm only which would explain why it doesn't do it during the cold fill for rinse. You probably need a fill valve but listen carefully and make sure noise isn't caused by the pipes coming to the machine. If it is 5 yrs old go ahead and replace supply hoses also, this is standard maintainance at that age.
Oct 05, 2007 | Roper RAX7244KQ Top Load Washer
Noise
Eileen, If the screeching is only happening on the fill and not during agitation or spin, I think we are safe to rule out the belt, pulley and bearing. Remove the fill hoses from the back of the washer and check to see if you have sand or gunk caught in the screens of the valve itself. If they are clear sounds like the water passing through the valve is making the noise. Another thing to check is the water pressure in the house. It should be around 55 psi., 75 psi max. I have seen it as high as 120psi with a bad regulator. This will cause noise and all kinds of problems. The part number for the fill valve is 131389300, according to the model posted....Catriver...post back.
Aug 27, 2006 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
241 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
