According to autozone.com under their 'Product & How To' procedures,
Inspect/Replace
There can be slight variations in procedure from one model to another when replacing headlights. For instance, on some models the turn signal light assembly must be removed before the headlight can be replaced. Overall, however, the procedure does not differ much from the following typical instructions.
Make sure the replacement bulb is the same type and part number as the one that is being replaced.
Comparing the old and ther replacement headlamps.
To Replace:
HEADLIGHTS NOT WORKING
It
can be faulty headlight switch or issue with its wiring. Or its faulty head
light fuse.
To
troubleshoot the issue i suggest you few help links with appropriate solution.
So you can follow the test and confirm what exact problem is there in your case
of headlights not working:-----
Click
the link below: -----
http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
• Working of Headlight switch?
• Both headlight bulbs blow together?
• Car
headlight bulbs don't last long?
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
How to Replace a Headlight
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight.html
Bulb
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-bulb.html
Switch
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-headlight-switch.html
How to Replace a Headlight Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-assembly.html
How to Replace a Park Light Assembly
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-park-light-assembly.html
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-headlight-door.html
http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
These
will help.
Thanks.
How to Replace a
Headlight Switch
Low beam headlights Modification?
Headlight Assembly Removal On Honda Accord
http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html
Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
How to Replace a
Headlight Door
All headlights not working?
How to replace HID headlight bulbs for lexus
400h?
• Car headlight bulbs don't last long?
These will help.
Thanks.
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
Only one head light
works on 2001 Dodge Caravan?
http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
Headlight wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
Dash Lights And Front
Marker Lights Flashing On And Off
http://schematicsdiagram.blogspot.com/2012/10/dash-lights-and-front-marker-lights.html
2001 Chevrolet Tracker: Headlights and Dash
lights Pulsating?
http://whoisbyme.blogspot.in/2012/06/2001-chevrolet-tracker-headlights-and.html
No parking lights and headlights not turning OFF?
http://technoanswers.blogspot.com/2012/01/no-parking-lights-and-headlights-not.html
400h?
Head
Lights Comes ON by Itself?
http://whoisbyme.blogspot.in/2012/07/head-lights-comes-on-by-itself.html
Only high beams work but head lights not
working on Ford F350?
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
http://howtobyme.blogspot.com/2011/12/how-to-replace-headlight-bulbs-on.html http://repairhelpcenter.blogspot.com/2011/12/how-to-change-headlight.html ------------- http://technoanswers.blogspot.com/2012/01/headlights-will-not-turn-off-on-ford.html ---------- http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html --------- http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html ---------- http://schematicsdiagram.blogspot.in/2012/02/using-non-afs-headlamp-assembly-for-afs.html ------------ How to
replace Headlight Bulb on 2001 mitsubishi magna
Only high beams working on GMC Savana?---------
How to replace Headlight Bulbs on Lincoln
Town Car?
How to change headlight?
Both headlights and turn signals not working?
http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
Headlights will not turn OFF on Ford expedition and car trailer?
Headlight Assembly Removal on 2010 buick lacrosse?
http://technoanswers.blogspot.in/2012/04/headlight-assembly-removal-on-2010.html
Headlights flickering and car hesitates to
start?
Hummers headlights flashes while start?
Using non-AFS headlamp assembly for AFS
assembly?
http://www.howtorepairguide.com/2012/10/how-to-replace-headlight-bulb-on-2001.html
These details will help.
Thanks.
