Question about Refrigerators
Not cold - Refrigerators
There is only a 30 degreee spread between the outside temp and inside normally....if the fans not running take the silver cover off the back of the uint...at the top of the unit there is a circuit board...on the left side on the board there is a 5 amp fuse thats probably bad. You'lll need a soldering iron to take it out and install a new one....i checked mine out...it draws 4 1/2 amps but its fused at 5amps....too close...i popped another fuse yesterday...maybe move the fuse up an amp or 2 in the future to 7amps or so.....hope this helps
Posted on Jul 03, 2008
I’m a Shaw customer and I’m moving to Cold Lake AB. I have purchased my Shaw box, for cable TV can I use it in Cold Lake AB. Is there Shaw in Cold Lake AB
yes there is
Search Results
Satellite TV Cold Lake, AB ' Shaw Direct
https://www.shawdirect.ca/order/alberta/satellite-tv-cold-lake Choose the satellite TV package in Cold Lake, AB that fits your lifestyle and budget. Get more options and more entertainment for less.
Shaw in Cold-Lake-AB ' YellowPages.ca™
https://www.yellowpages.ca > Canada > Alberta > Cold Lake Locate and compare Shaw in Cold-Lake-AB, Yellow Pages Local Listings. Find useful information, the address and the phone number of the local business you are looking for.
Shaw Cable in Cold Lake AB ' YellowPages.ca™
https://www.yellowpages.ca/search/si/1/Shaw+Cable/Cold+Lake+AB Locate and compare Shaw Cable in Cold Lake AB, Yellow Pages Local Listings. Find useful information, the address and the phone number of the local business you are looking for.
Cold Lake, AB Compare 16 Internet Providers ' FindInternet
https://www.findinternet.ca > Home > Search > Alberta Research and view all Internet providers in the Cold Lake area. Find all Internet options with accurate plans and pricing from Xplornet, TekSavvy Solutions Inc. and 14 other providers! Shaw in Cold Lake AB Google Search
Apr 21, 2018 | Televison & Video
99 contour starts easy idles smooth, cold but dies when you start to pull out runs well when warm
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 06, 2012 | 1999 Ford Contour
2006 nissan navara wont start in cold weather
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
Idle fluctuates when cold 93 bonneville
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Maytag ensignia washer...cold water settings
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Feb 16, 2018 | Maytag Ensignia 3.3 cu. ft. Top Load...
Kenmore front load washer: no cold water problem
that's odd.
if you choose cold/cold then check your hose orientation. you could have put the hot water to the cold solenoid.
or the wires have been interchange, the hot water wire was plug to the cold solenoid and the cold water wire was plug to the hot water solenoid.
or hot water is still flowing to your cold water line.
if the cold water solenoid is the problem, then there should be no water at all going to the tub.
try to experiment, try to switch to hot/hot and see what would come out...
tnx 4 using fixya,
drcool
Oct 02, 2008 | Kenmore Energy Star 44092 Front Load...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
