Question about HP Photosmart C6180 All-In-One InkJet Printer
I can send faxes but not receive them
How do I go about receiving a fax I have a separate phone line for it but it will not work . it shows connecting but then says received failed
    Novelist:
  • 106 Answers
below is the document that i want you to check so that you will know where to start determining which part is causing the issue.
RUN FAX TEST click here==> DOCUMENT
please let me know if the issue is resolve or not so that i can go ahead and give you another possible solution for your issue.
thank you so much.
adonscott
Posted on Jul 07, 2008
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
I'm not sure what type of machine it is but I think it's a Brother. It has a separate fax line and isn't connected to a computer or network or anything like that. The machine will receive faxes fine but...
Are you working with a line over VOIP like Vonage? If so faxes can be hard to send and receive because of line condition.
Also, if you have DSL make sure that you have the proper line conditioners in place so you have good line condition.
If those aren't a problem then contact your phone provider to discuss the issue.
Mar 03, 2011 | Office Equipment & Supplies
I CAN SEND FAXES BUT NOT RECIEVE
The majority of the time, when you can send but not receive, it is a phone line issue and not the machine. Extremely rare does a machine send and not receive. So here goes the things to try and the reason. 1, Make sure the phone jack is in the "Line" jack and not the external phone jack. Believe it or not, that is the number one issue with sending and not receiving.
Next, plug a phone into the jack that the fax machine is plugged into and see if there is static.
You want to be sure in the fax \settings and advanced settings that the ECM mode is ON, and that Junk Fax ius turned OFF, Junk Fax being on will stop almost all fax from comming in.
Now, the phone line. Here is the explaination of why that can be the problem. When you send a fax, you manually make the connection to the line. When you press send a relay flips and connectes you to the phone line, therefore you have made pretty much a mechanical connection enabling the phone line, and therefore you can send.
Now, when you have an incoming fax, several conditions must me met to make the handshake and therefore connect and receive. These all have to be right in order to properly receive. The phone line voltage mist be high enough, the phone line current must be correct and there can not be much decibel loss over the line. You are making a signal connection, all those conditions must be right to receive a fax. Think of it like a TV remote with batteries that are almost dead, It still send out some signal, but it will not change channels or change the volumn,etc etc. Same principle. If the signal to the incoming fax is weak, chances are it will not connect.
Jun 13, 2009 | Office Equipment & Supplies
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Cannot send or receive faxes.
Try a phone hand set on the wall jack to make sure you can get a dial tone and the line is alive.
Then plug the fax phone line into that wall jack. Make sure the phone line is also in the right port on the back of the Officejet printer, where it most likely says LINE -IN and NOT where it shows an image of a phone set.
RDO
Nov 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Fax machine will send out but will not receive any
Sep 24, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Jul 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cannot receive faxs
The majority of non receive issues are phone line problems.
3 conditions must exist for a fax to receive, the phone line voltage must be high enough, the phone line current must be high enough the the DB gain must be correct.
A fax receive should be viewed in the same way a remote controle works.
When you send a fax, you manually access the phone line when you select send, you connect to the phone line, normally via a relay. Once that physical connection is made, it can send anything. Maybe not well, but it will send.
Where as receiving is an electrical signal that activates the machine. If your phone line is not up to standard, its like haveing a remote control with weak or dead batteries and trying to turn on your TV with those weak batteries in it.
Issues, simply a bad phone cord between the machine and phone jack. Some resistance may have acrured over the years. The phone jack itself may have a poor connection.
A staticy phone line will cause a fax not to pick up. Plug a phone into that line and see if there is any noticible static.
Multiple devices plugged into the phone line with the fax machine. ETC an answering machine, credit card machine, etc can cause more of a draw on a shared line, if that is the situation, at least for a test, remove everything but the fax machine from the line and see if it receives then.
Rarely if the machine can send and not receive is the machine an issue.
Have your phone lines checked well and that sould resolve the issue. And make sure the line is not plugged into the extension or phone jack on the machine, but plugged into the line jack. That is also a common problem.
Apr 30, 2008 | Office Equipment & Supplies
Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
Jan 31, 2008 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
