Question about Canon PIXMA iP1800 InkJet Photo Printer
Paper Jamm Reead Manual and removed the paper by pulling straight up and out. One corner of the paper still in the printer. Can't see it. Can you help.
  • ruthclark Jul 03, 2008
    Success! Rolling did not do it! Seen paper in small opening on the right, figuired what have I got to loose. Got paper clip and tweezers. Only took 2 minutes and it works fine. Thankyou so much for giving me the nerve to fix.
    President:
  • 1,257 Answers
    Genius:
  • 1,847 Answers
Give slight **** and pull the papper out.
Posted on Jul 03, 2008
  • Legin Varghese
    Legin Varghese Jul 03, 2008
    manually roll the roller and pull out the paper out.
Hp laserjet 3015 paperjam
Plz see if the corner of the paper will be folded or it has been folded earlier and now it is straight then also that paper will be jammed. So use new unfoiled paper.
While inserting it see it is straight in the tray.
Oct 26, 2012 | HP LaserJet 3015 All-In-One Printer
Paper jamm
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Oct 13, 2011 | Lexmark X6675 Pro Colour Wireless...
What does the "heart beat" symbol/light mean?
I assume you mean the symbol that has a pair blackened circles and then a pulse up and then down below the starting line before returning to the starting line.
That is the paper jam symbol. If the continue light is on (steady) and the paper jam light is on, then you have a paper jam. Press Continue twice to see any secondary error message (this will show where the problem is).
See the manual for the list of the lights that show where the jam is occurring. Different groups of lights will be lit. The manual is available as a PDF at the bottom of this page: http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN . An example: if the Continue, Toner Low and Paper Jam are all on, then the jam is in the fuser area under the print cartridge assembly. For a paper jam, even a small corner of torn paper could be in the mechanism.
In all cases, you should check the entire paper path. When you pull out any paper, grip it so that you can gently pull the sheet straight out. Remove all paper from the output tray. Then remove the paper tray if you are using it. Pull any paper from this area. Press down on the green duplex flap and remove any paper from there Reinsert the paper tray. Open the front door of the printer and remove the print cartridge assembly. Lift the green flap and remove any paper from the area. NOTE: the fuser and the fuser area may be hot. Open the rear exit door and remove any paper from that area. Use a flashlight to check for small pieces of paper that may be stuck. Once all the paper is removed, reinstall the print cartridge assembly and close all the doors. Press Continue to reset the printer.
The page that jammed may be reprinted.
I hope this helps.
(please note that frequent paper jams may be a sign of excess humidity in the paper. Put less paper in the tray at each refill and keep the remaining paper in a dry location. If the paper jam light is coming on when no paper jam is present, one or more of the paper jam sensors may be bad. Contact Lexmark for more information.)
Nov 30, 2010 | Lexmark E250dn Laser Printer
Remove jamm paper from the hp laserjet 1018
bring out your catridge and try to pull out the paper out of the printer, lastly use forceps for the resedual paper stuck into the paper roller
Apr 13, 2010 | HP LaserJet 1018 Printer
My MX310 got a paper jam and when i pulled the paper out a small piece of the corner tore off and is still stuck in the printer. The printer now continues to claim there is a paper jam but i cant visually...
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
Jun 05, 2009 | Canon MX310 Office All-In-One Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Paper wiil no feed
I am also having the exact same problem. I have to print things 5 plus times until I get it straight on the paper. It pulls pretty bad. I wish someone could tell ME the solution.
May 04, 2008 | Lexmark X3470 All-In-One InkJet Printer
PRINTER MP210
Problem seems to be in the design. The paper loading roller pulls on the corner of the sheet,cocking it to one side. If the paper was pulled in from the center of the sheet,it would be pulled in straight and evenly.
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
50 people viewed this question
old marine
old marine
