I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
  • Tim Babcock
    Tim Babcock May 11, 2010
    What brand of wireless router is this?
    Sergeant:
  • 313 Answers
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Posted on Jul 03, 2008
After installing when connection to net it says view network security setting what to do
Go to security settings and either follow the security setup and use WEP. (Easy security key is your whole tele#) or leave it unsecured and open for the whole neighborhood.
Nov 30, 2010 | Belkin Basic Wireless Router
My WRT54G lost its security setting and also its network name
Log on to Rtr Setup using Default Gateway.
You will find security centre , where you can set up security for the existing network name .
May 31, 2010 | Linksys Wireless-G WRT54G Router
The router was reset as other computers could not connect with the security password. When attempting to set the network with the requested PIN, the router would not allow it. Currently wi-fi access is...
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 26, 2010 | D-Link DIR-615 Wireless Router
I am trying to add a password to my wireless internet connection (D Link Router), so it cannot be accessed by everyone in my neighborhood. I am a mac user.
Dec 26, 2009 | D-Link 4-Port Ethernet Broadband Router...
Hi, I have a D-Link Wireless N Router DIR-615. It works great for our family's notebook computer and automatically connects with a stron signal. I just bought an Ipod Touch which prompts me to join the...
When you set up your router you probably assigned and administrators password to restrict access to the routers admin pages. When enabling wireless security a security key would have been assigned to authenticate clients attempting to attach to the router. It is the security key that the Ipod needs to access the router. To verify what the security key is login to the routers admin pages and check it.
Dec 18, 2009 | Computers & Internet
How do I set up a password or protect my wireless from letting everyone in the neighborhood use it. I got the router sometime ago but never found out how to protect my connection. Now I am worried about...
Your default Ip should be
192.168.1.254
Open internet explorer and type that into the search bar..
it should ask for a user name and password, if you never set it for your router before, leave both blank.
that should open up your routers configuration page.. now click on wireless security and turn on either wpa or wep encryption and choose a password.. once you do so you will have to reconnect to your router and then enter the password you just created..
Now you network is protected and only people with your password will be able to connect wirelessly..
Nov 02, 2009 | Blitzz Technology (BWA611) Router
I have a belkin G router that my computer will not recognize for some reason. It recognizes every other network in the neighborhood except mine. There is no security or password set, and my wifes computer...
Check whether the SSID broadcast is enabled on the router.
If it is already enabled then try changing the wireless channel on the router.
for this you will need to open the set up page of the router.
Click Here for more info about networking
Oct 13, 2009 | Belkin (F5D8231-4) Wireless Router...
Acer notebook with Vista won't connect to home w/l network
Use this tip for a check list : band, encryption, protocol (WPA, WEP?) Do you see your radio signal (SSID)
Do you set an access list on your router? add your Vista PC MAC address to router list or disable access list control.
Be sure to browse internet using a cable connection to router
Try removing access security and check if connection performed
Restore security protection and match router/pc settings,
Feb 16, 2009 | Acer Aspire 4315 Notebook
Computers & Internet Logo
535 people viewed this question
David Payne
David Payne
