Question about Whirlpool Calypso GVW9959K Top Load Washer
How do you remove agitater on on Whirlpool Calypso?
I have a huge chuck of a lightweight comforter. Can you you give me a little guidence on how to remove, please? You cam email me at
Thanks alot, take care dutchm.
  • d3kelly8 Jul 05, 2008
    how do i take the agitater off
  • Anonymous Nov 11, 2008
    sheets are now stuck under the agitator. how do i remove them without ripping up the sheets?
    Problem Solver:
  • 15 Answers
Chin Sao mua te quempo
Posted on Jul 13, 2008
Whirlpool calypso washer smells how to get rid of ordor
Removes odor causing residue in front loading (HE) washers. Keeps your machine fresh and clean. Package includes 3 tablets. For front load washers only.
Here is what you need.
Oct 18, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Keeps giving me an Ld on the little screen, what does this mean?
long drain
it probably is not draining
this is a calypso right?
i cannot believe this would be your first problem with this washer?
have you ever had work done on this before?
i am trying to find out if you have had your pump replaced before?
if yes this will make it easier for you
let me know
Feb 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How to clean the screen under the agitater
Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
Jan 28, 2010 | Whirlpool LSR7333 Top Load Washer
Hi all, we have a HUGE problem....our calypso washing machine has a problem with the agitator seal resulting in clothes being caught underneith the agatator. Is there a known design problem with this type...
The problem you are experiencing is caused by overloading your machine. When the clothes are just below the top of the agitator you have a full load. If you add more clothes than that you are overloading and your problem will continue.
Aug 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washes spins but do not drain the water out what could be the cause
the DRAIN MOTOR PUMP is clogged , need to open washer , disconnect the drain hoses , take out the little motor pump , and remove any debris and lint collected , hope this helps, AJ
Jul 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL Code on whirlpool calypso
Flood Condition - overfill; excess water in the tub. With this condition the beeper repeats a warning every 10 seconds with no timeout. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is disconnected from the unit.
May be a sign of a pump motor problem - clog, jam or failure. There is a redesigned single piece pump/impeller assembly that you should upgrade to if the unit doesn't already have that kind, if it turns out the pump has failed.
You may be able to clear the fault by removing debris from the pump water tubes or impeller. I've had to disassemble from the bottom of an unplugged unit to get a draw string out of the impeller, or a sock out of the ball valve which reverses the flow of water when the pump changes direction.
Takes a little practice, but it can save big on repair bills if you are comfortable poking around underneath a drained washer. Problem is, when you have a FL condition, you may have to bail out the water or use a wet/dry vac to **** it out of the drain tube, to avoid a mess in the wash room.
Jan 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Now do you remove agitator from washer drum?
washing machine is not working properly kindly advise who can repair in south delhi in Devli Village, Near Khanpur, New Delhi-110062
Jul 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso - Will not start
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Oct 12, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
