Question about RCA Televison & Video
Broken coaxial cable connector (on the b ack of the television.
  • RCA Master
  • 2,794 Answers
In most cases that can be repaired easily by a technician
Posted on Jul 03, 2008
How do i connect my directv box to my soyo tv #DYLT032D
  • If your DirecTV box supports HDTV then connect it using either an HDMI cable from the box to the TV (located on the back, labeled HDMI 1,2,3,etc.).
  • If the box is not an HDTV box then connect it with a RGB (red, green, blue) composite cable from the box to the TV.
  • If the RGB output is not on the ack of the box then connect using a standard coaxial cable.
[NOTE] In order for the quality of the picture to be HD, use the RGB for digital (Better), or the HDMI for High-def (Best)
Mar 02, 2011 | Soyo DYLT032D 32 in. LCD Television
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
Where can i find a cable for my HDTV (the kind that get screwed in)cables? its a Mitsubishi WT-46805
Hello sounds like the coaxial connector has come off or broken off the tuner, You can repair this problem using the old connector that broke off by taking out the tuner and resoldering the center pin back to the tuner board (provided the small tuner board is not cracked) and the out side of the connector to the tuner housing for ground. If you are just using or referring to a common coaxial cable to purchase, you can get these from everywhere Radio shack, Fry's etc. Also ur local cable company. If all else fails use the rca output jacks from the cable box if u have one and connect it to video input one on the back of the television, make sure you change you television input to video one if u decide to do it this way.
Oct 24, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Coaxial connector broken
I have a magnavox plasma 50", when i remove it from the table i forget to unplug the coax cable from the back of the tv so i pull the connector out from it, anyone tell me what can i do to repair or replace this solution?
Jun 04, 2009 | Philips Magnavox MT1905B 19" TV
Broken ps2 connector ACK-595 Keyboard
go to this webpage http://en.wikipedia.org/wiki/PS/2_connector there´s a list of different wire arrangements it could help you.
Nov 22, 2008 | Adesso ACK-595 Keyboard
Coaxial output broken
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Oct 24, 2008 | Sanyo DS20930 20" TV
No coaxial connector on tv
if it has an antana input the two screws on the back, you get an adapter from almost any department store for around 3 bucks.
Aug 16, 2008 | GE 35GT740 35" TV
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Coaxial input jack on the TV broken off so I cannot connect my coaxial cable from wall
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Sep 18, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
