Question about Vacuums
Hoover Handle Release Pedal Replacement--How is it possible?
Sir,
I have a hoover u6634-900. Momma broke the handle release pedal, so it flops and is very hard to use. I found a replacement part on the internet, but cannot figure out how to get the cover off and/or get to the section where I can replace the part. Additionally, I bought the idler arm lock because the name made it sound like it should be replaced...but I don't know if that is necessary.
Thanks a million if this all makes sense.
Mike "Hi Ho" Silver
  • 2 more comments
  • HiHoSilverF Jul 03, 2008
    I think I found the three screws and removed the two knobs (#2 above...maybe that was not necessary, but one came off while I was messing with it). I cannot for the life of me find the slot on each side. Is it towards the front or back? How is it best to hold the vaccum to locate them and take the top off? Thanks for responding so quickly Mr. Reddevil6. If I can get this fixed over the holidays, then I will be a hero with momma.
    Have a great 4th...
  • HiHoSilverF Jul 07, 2008
    Reddevil6,
    I can fly an F16, but I just cannot find the slots. I inserted a photo of the vaccum's bottom...can you move the arrows around to point me in the correct direction please? When you say flat blake, is that a screwdriver or puddy knife size?
    Thanks for your patience...
    HI HO
    I guess my picture was too big...I am trying to resend. Thanks. HI HO
  • HiHoSilverF Jul 08, 2008
    RedDevil6,
    You are the man! Wow, that was awesome. My spouse is gone for a couple days, but she will be thrilled the first time she uses it. Thank you very much for your expertise and patience...Mission Complete!
    Hi HO
If you look at the picture, the slots are right across from the drive wheels, you can see the slots in the picture. Use a flat blade screwdriver.
Posted on Jul 07, 2008
    President:
  • 1,673 Answers
Remove the brush roll, then there 3 screws to remove from the bottom. Then on each side there is a slot, use a flat blade and push on them, then the top rill come loose. That idler arm lock is # 4 in the picture and the knob holds it in place, unless it came off, you don't need to replace it. The handle release #6, there 2 tabs that fit into a holder on each side, stick your screw driver in there and try to twisp and pry it out from the holders, then pop in the new one.
Posted on Jul 03, 2008
  • Lauren Junge
    Lauren Junge Jul 03, 2008
    The slots are one on each side, from the bottom. You may have to undo the hose from where it is fitted into on the side of the vacuum so the top will come off.
  • Lauren Junge
    Lauren Junge Jul 08, 2008
    Glad I could help. You mentioned flying an F-16, I can't fly a jet, but used to work on the F86 and F102, used to be an instrument repairman. But that was a long time ago.
How to change the release pedal on Hoover SteamVac F5914-900 SpinScrub
99 out of 100 times it's not the handle release pedal that's broken. it's the knob on the rear housing broken off. You will have to replace the rear housing. Take it to a local vac shop for repair.
May 07, 2017 | Hoover Vacuums
Can't lower handle on Hoover wind tunnel vac U6432-900
Anne, Do you mean that when you depress the pedal on the left side of the machine body that you can't get the upper portion to release into a lower mode? Or are you fully depressing the pedal?? As for the switch for the self propelled mode, that's actually just a small button that you move around in the slot of the handle to select which mode you want to use. It's not actually a switch. If you are fully depressing the handle release pedal and it's not releasing, you should take it to the store where you purchased it, if it was a vacuum store. If you bought it at a big box store, then you'll need to take it to some repair shop that does warranty work, if it's within the warranty period of course.
Nov 10, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot remove handle from Hoover Dual-Power Carpet Washer
Cannot remove handle or release handle?
Release from the center pedal at the rear of the unit. Rove the handle with 2 long narrow bolts located near the half way point from handle grip to the base; don't loose the two small nuts or you'll have a bad time.
Nov 06, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Need to preplace handle release pedal
To remove the old pedal, simply insert a screwdriver along it's outside edge, and pry upward to pop it out. The new pedal, (#38434026) can be pushed into place with your fingers. Install it with the handle in the upright position.
Feb 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Mar 11, 2010 | Hoover Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
Handle foot pedal release U6425-900
I have the exact same problem. I can't even open the unit up. Let me know if you found anything out. I have searched the web and can't even find a service manual to purchase ! Thanks.
Apr 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
354 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
