RCA M202C SD CARD PROBLEMS
256 MB RCA M202C WILL NOT READ A 1 GB SD CARD. WHAT IS THE PROBLEM? RCA IS NO HELP. IT TOOK THEM 3 DAYS TO SAY NOT TO USE SD HIGH CAPACITY. I DON'T KNOW WHAT THAT MEANS. IT ALSO SAID 1 GB OR LOWER WAS COMPATIBLE.
5 Suggested Answers
SOURCE: SD card in MP3 player
Was the SD card in the MP3 player when you loaded the songs or did you load them some other way?  You may have to first put the SD card in the MP3 player first, then load the songs onto the player.
Posted on Oct 17, 2007
egoboss187
  • 53 Answers
SOURCE: ipod problems
reformat the ipod through my computer using the right click on your mouse then see if the problems go away
Posted on Nov 29, 2008
Maanita
  • 1142 Answers
SOURCE: 40 GB Kingston Pendrive Showing 8 MB & unable to format it.
Format it using a format utility which you can download it from any free software sites, type in format utility.
Posted on May 04, 2009
SOURCE: sansa mp3 player could not detect micro sd add on card
you can change it undr Settings and then scroll around to USB. tap the >>| button and change the USB settings there.
Posted on Nov 21, 2009
SOURCE: Don't have a user manual for the RCA M202C Audio Player
I cant get the song to download to the card..what am I doing wrong
Posted on Apr 26, 2010
Why won't my camera won't read the sd card I'm using?
8 gB is SDHC. Try less than 4 gB maybe even 256 mB to see if it will read those cards. But lately, all stores only sell HC cards. Try ebay, and they may charge an arm and a leg for old cards?
Feb 15, 2012 | Panasonic SV-AV25 Digital Camera
What maximum capacity Memory card of SANDISK is suitable for Coolpix 5600 ?
I've search and found that there's no limitation in SD card usage, it only said we prefer more than 256 MB card. But there is user who use 4 GB SD card, so I think it would be fine for you to use it. Higher memory card usually will make the camera harder to read the data, so I can't guarantee if you use higher memory than that.
Hope this help and RATE please !
Jan 16, 2011 | Cameras
I can't find the memory card for it
According to the specifications the camera has both an in-built mmory, and also accepts an SD card with a maximum of 512 MB . Maybe it will accept a larger SD memory card but only record up to 512 MB? I do not know.
SD cards are common in camera stores, but these days they make them with 1, 2, 3 or even 8 GB ( 1GB about 1000 MB) !
Dec 24, 2010 | Creative Labs DiVi CAM 316 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Black screen
If you have an onboard video card, that won't be enough to run the game. Try updating your graphics card. Here are the requirements to successfully run the game: suggested system requirements: Pentium III 1 GHz, 256 MB RAM, graphic card 32MB (GeForce 2 or better), 1.2 GB HDD, Windows 2000/XP
May 07, 2009 | EA Sports Cricket 07 for Windows
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
Not recognizing music on SD card
Not sure if you have found the solution to your mp3/SD-card problem, it has been almost a month. Obviously I had the same problem. That's how I found your question. What I did was re-format both the mp3 and SD, then loaded the SD card first and sofar so good.
Jan 10, 2008 | iLO (2 GB) MP3 Player
Mp3 player wont read sd card
the reason for your problem is that the rd2312 can only handle a 1 gb card
Apr 15, 2007 | RCA RD2312 (256 MB) MP3 Player
150 people viewed this question
 Grubhead
Grubhead
