Question about HP DeskJet 6540 InkJet Printer
HP Deskjet 6540 Alignment
My printer continue to print as if the carriage is loose.Both cartridges are printing fine,just seem to (shift) while it is printing,making each character be slightly moved while it is being printed and at the bottom of the page all printed characters are shifted to the right edge of the page.
    Novelist:
    Scholar:
  • 70 Answers
Yeah, the only thing that can cause this is paper feed problems.
There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
Posted on Jul 03, 2008
My hp deskjet 6540 prints ok at first but then halfway down the page the black turns brown, then red!
Please check your ink cartridge. If it is old change it. Also clean the nozzles. After doing this print the test page.
Jan 14, 2011 | HP DeskJet 6540 InkJet Printer
I have an HP Deskjet 6540. What do the two orange lights near the on/off switch incicate?
The HP Deskjet 6540 series printer has two print cartridge status lights. The left light corresponds to the left print cartridge, and the right light corresponds to the right print cartridge.
Jan 08, 2011 | HP DeskJet 6540 InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Have hp deskjet 6540 printer. yellow light on right side under x keeps blinking not printing. Am I out of ink?
    Follow each of these steps until the problem is resolved:
    Remove and then reinsert the print cartridge(s) into the printer.
    Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
    Manually clean the print cartridges and print cartridge cradles:
    Open the printer cover and wait until the carriage moves to the center.
    Press the Power button to turn off the printer.
    Disconnect power cord from the back of the printer.
    Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    Lightly moisten a cotton swab with distilled water.
    Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    Reinsert the print cartridges.
    Close the printer cover.
    Connect the power cord to the back of the printer.
    Press the Power button to turn on the printer.
    Calibrate the print cartridges.
    If the light is still flashing, replace the print cartridges.
    Aug 24, 2010 | HP Office Equipment & Supplies
    How do I change ink cartridge on my HP inkjet 6500 wireless printer.
    Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
    The methods of replacing the ink cartridge of the printer follows here:
    The printer ink carriage will automatically goes to center
    Once the carriage is in the center, the printer was ready to replace the ink.
    Pull the down slowly the ink tank off the carriage..
    Remember the place where the color/black position.
    Remove each tank one at a time, and replace the ink with a new one.
    Close the printer cover and it now ready to printer.
    HP Deskjet 6500 Series Printer - Setting Definitions
    Hope the instructions provided helps.
    Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
    I used Word and Notepad and Wordpad to print documents and the printer shoots out blanks...or one partial page then blanks..i've uninstalled and reinstalled both Word and HP 6540 and i did so...
    It really sounds like you might have bad ink cartridges, if you use re-filled cartridges they often have problems like you are describing. The ink will get clogged and not make it to the spray nozzel so the printer thinks its printing, but the ink isnt being sprayed onto the page.
    Sep 12, 2009 | HP DeskJet 6540 InkJet Printer
    Printing is off center on the HP 6540. The image or page being printed is cut off on the right margin and on the bottem of the page.
    ok, most likely your printer cartridges are off. In order to fix this, you can use windows to align them. Click start > Control Panel > Printers and Faxes, and right click the printer thats giving you trouble. Then go to properties. Next, go to the services tab, and click align the cartridges, and continue from there.
    Sep 01, 2009 | HP DeskJet 6540 InkJet Printer
    Hp deskjet 6540 carriage out of alignment
    Probably a small piece of paper (now black with ink and hard to see) stuck in the extreme corners (probably the left side).
    Jun 21, 2008 | HP DeskJet 6540 InkJet Printer
    HP Deskjet 6540
    The color cartridge sping was loose. I am in the process of super gluing it into place. Hopefully it will work.
    Mar 19, 2008 | HP DeskJet 6540 InkJet Printer
    HP DeskJet 6540 InkJet Printer Logo
    177 people viewed this question
    Seeker5211
    Seeker5211
