Question about Sharp AR-M277 All-In-One Printer
Black lines showing up on documents fed thru the document feeder.
Black lines show up on every copy fed thru the document feeder of my office jet all in one printer(HP)
  • Tim Babcock
    Tim Babcock May 11, 2010
    This was posted in a Sharp subject area. What is the model number of your HP printer that is being afftected?
Clean the small glass under the doc feeder very very well...
Posted on Jul 03, 2008
I have ir 400 machine comming black lines problem in the copy
Does it show from the document feeder and the flatbed? If it's just when you copy from the doc feeder it's probably just dirt on the glass where the original passes over it. Just give the glass on the flatbed a good clean . Especially the slip of glass on the end.
Nov 12, 2017 | The Office Equipment & Supplies
HP5610 - HORIZONTAL STREAKS ON COPY & SCAN
Yep, only when you use the document feeder? If so, lift the document feeder lid, get a clean lint-free cloth and some glass cleaner. Apply some of the cleaner to the cloth then, clean the small of the two glass areas. That is the only section that reads documents fed through the document feeder! Run a blank sheet of paper through the document feeder first before cleaning and make a copy. Take the copy and, if there is a line (or lines)on the copy, place it on the larger document glass face up.Follow the line to the smaller glass. The dot of debris will usually be there. If you don't see anything wrong, clean the glass anyway. Run another blank sheet through the document feeder. Check that copy. If the lines are gone...Viola! you have solved the problem. It it has not and you've cleaned it more than once, the debris is on the mirrors under the glass and a technician will need to come out, remove the glass and carefully clean the optics/mirrors.
Good Luck.
Aug 28, 2017 | HP Office Equipment & Supplies
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Black vertical line in scans and copies when fed through top document feeder.
clean your scan glass (thin strip of glass running from front to back, underneath document feeder) with a soft cloth and alcohol.
Jul 16, 2009 | HP Officejet 5780 Printer
HP color laser jet 2840 feeder is broken
something might be blocking the light from the scanner lamp to fall on the originals. Try cleaning the glass covering the lamp.
May 23, 2009 | HP LaserJet 2840 All-In-One Printer
Black line when using feeder
Not familiar with this model in particular, but if you lift the document feeder, as if to place an original on the glass, there is either a narrow filter glass on the left of the main contact glass, or in many cases it is attached (clipped on) and lifts up with the document feeder cover. Clean this glass. If it is clipped on to the cover, remove it, and clean both sides. I hope this helps.
Please rate solution :)
Apr 24, 2009 | Office Equipment & Supplies
Making a copy
Open the document feeder and clean the scanner glass.
Feb 26, 2009 | Office Equipment & Supplies
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Sharp AR-M277 All-In-One Printer Logo
180 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
