Question about Technics SL-1210 Turntable
Technics turn table
When i put the arm over the disk and move down the lever the apm stays into the up position.
It has to do with an adjustment?
Under the tone arm next to the lever ther is a sort of plastic bar which lifts the tone arm when lever is up right, look along that bar and there is a screw which you turn as you would to tighten anything.you will see the bar move down,try again and if you still have the same problem repeat the process till done......
Posted on Jul 07, 2008
How do I get the turn table to move into play position
When you say the 'turn table into the play position' I assume that you mean the stylus arm (that holds the needle). Make sure that the turntable is made to automatically move the arm into the play position. Some turntables are manual, and do not have this feature. If yours does, the mechanism operates off a series of levers and cams that are operated off the turntable motor. Make sure that they are not jammed, and are lightly lubricated. There should be a lever control that sends the unit into the automatic mode. Move the lever to automatic, and watch the mechanism move and see if it is being jammed.
Mar 25, 2015 | Audio Players & Recorders
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
Kohler V-Twin (624 cc) RPM on the engine does not stay stable , It will raise and lower the RPM in any Throttle Range. Could the Governor be going bad???
Try a static governor adjustment first as it simply be out adjustment.
Static Adjustment Procedure
Make this adjustment whenever governor arm is
loosened or removed from cross shaft. Adjust as follows:
1. Make sure throttle linkage is connected to governor
arm and throttle lever on carburetor.
2. Loosen nut holding governor lever to cross shaft.
3. Move governor lever toward carburetor as far as it
will go (wide open throttle) and hold in this position.
4. Insert a long thin rod or tool into hole on cross shaft
and rotate shaft clockwise (viewed from end) as far
as it will turn, then torque nut to 6.8 N·m (60 in. lb.).
Aug 23, 2014 | Garden
I have a Kohler V-twin (624 cc), when you start the Sears Garden tractor the engine starts raising and lowering RPM, could the governor be going bad!!!
Try doing a static governor adjustment.
How to set the linkages and adjust a carburettor on a Honda HRU 195 mower
Turn the engine off, Put the throttle
lever to the HIGH position. Loosen the
pinch bolt nut on the governor arm a
turn or two; just enough that the arm will
move on its shaft.
With one hand, move the governor
arm so that the throttle plate of the
carburettor is wide open. With your other
hand, use smallish pliers that's
why there is a flat on the shaft to turn
the shaft in the same direction. Hold
everything in that position and tighten
the pinch bolt.
You've just taken all the slack out of the governor linkage.
Recheck the choke, idle and maximum RPM
and you've done all the adjusting
you can do.
Nov 25, 2010 | Honda Garden
My 2001 Dodge Caravan's transmission is stuck in reverse.
Things haven't changed much...look on top of the transmission in the engine compartment and look at the shifting linkage. Look for anything that could be interfering with the shifting. One linkage is the cable to the Shift Lever and Rod that goes down into the transmission. Remove the cable adjustment screw.
Move the shift lever rod towards the front of the Van into the Park Indent Position. Place the Driver's Position (Dash) Shift Lever into Park and then reconnect the Cable to the Shift Lever and tighten down the cable adjustment screw to 70 in-lbs.
Check operation's
Let me know if this helped, or if you have any additional information, questions of problems, Feel free to contact me at FixYa.com!
Jan 25, 2010 | 2001 Dodge Caravan
Hi. I'm have a problem with my Technics SL-BD20 turn table I've just purchased. When putting the arm onto the LP it just skips over the surface to the middle. Why does it do that? Cheers.
Try adjusting the tone arm weight so that the arm will be slightly heavier.
If this does not help, see if the tone arm manual lift handle is operational and fully released when the arm sits on the record.
Another possible cause are the tone arm position sensors inside the unit.
Hope you can fix it.
regards
Triarcuate
Oct 01, 2009 | Audio Players & Recorders
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Technics SL-1210 Turntable Logo
118 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
