Question about Frigidaire Dishwashers
Won't wash is new no water in but i have water at supply
    Novelist:
  • 161 Answers
Sounds like a bad fill valve. Replace it. Should cost around $25
Posted on Jul 03, 2008
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
Washer have a litter water come in
Hello Morris Daniels - Are the house valves fully turn on? Is the hose kinked or pinched? If not, then it sounds like you have an issue with the water pressure and possibly will need to replace the pressure switch. First try checking water pressure at another faucet in the house. Wait until water supply and pressure increase (water pressure for washer must be at a minimum of 30 psi). Straighten the water inlet hose if it is twisted or kinked. If any proves to be ineffective, contact a professional to move forward accurately.
Jan 03, 2013 | Frigidaire ATF6000ES Front Load Washer
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Open Questions:
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
