Question about Maytag Dryers
I believe the belt on my maytag electric dryer model LDE412 is going out. How to I get to the belt to remove it for replacement? Through the front of the dryer or the back?
    Scholar:
  • 170 Answers
Remove the front panel(s). and you will be able to remove the top panel, which will give you access to the top of the drum and be able to replace the belt. There should be a small pulley at the bottom of the dryer where the belt attaches to, as well as around the entire drum.
Posted on Jul 05, 2008
Replace belt
You can order a replacement belt if you know the make and model. Best to have a helper when replacing as it is hard to hold everything in place single handed. Are you sure it is the belt? Need to lift the top and remove the front in most front loaded "simple" dryers.
Jan 02, 2014 | Maytag PYE2300AY Electric Dryer
WORN BELT ON MAYTAG ELECTRIC DRYER
Remove the two brackets on the back holding the top on. Then pry the front part of the top off with a flat screwdriver. Next remove the electrical connectors. The remove the front panel. Then pull the drum out. Install the belt and push the drum in place placing the belt correctly into the tensioner for the belt
May 10, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
Rumbling noise when dryer first starts up. I can rotate the drum by hand and the noise is the same. Have also rotated by pulling on the drum belt and the noise is the same as well. Dryer Maytag Model...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 03, 2009 | Maytag Dryers
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Maytag LDE412 dryer.
Here is a link to the internal diagrams of your model.you can choose among the parts just in case.Good luck.Please do post comments and rate my answer.Thank you for contacting fixya.
LDE412 internal diagrams
Jan 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
LDE412 MODEL MAYTAG DRYER, LOUD SQUEEK
Are you sure that is the model number? I can`t find that model number anywhere. Please check the tag on the machine. This tag should also have the serial number on it.
Nov 10, 2008 | Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Dryers Logo
138 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
