Question about Ruud UAKA042 Air Conditioner
Compressor stops suddenly....and then starts again
My compressor will stop for a few minutes. The fan will click and turn a half a rotation and stop. This will go on for 5 minutes or so and then the unit starts up again. Is this a capacitor problem, electrical short or a freon problem?
Thanks
    Genius:
  • 1,122 Answers
Most condenser units have a fan capacitor and a compressor capacitor and some combine it into one,take your cover off and look to see what you have,i'am thinking it the all in one and it should be replaced,let me know-mike
Posted on Jul 03, 2008
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
I have a Tempstar 5000 that is about 15 yrs old and the fan motor to the outside unit will suddenly stop working and the compressor will start making a loud humming sound that does not sound too good. I...
Hello
Sounds like the condensor fan motor is going bad.If the fan stops turning or is not turning at full speed, the compressor can not give off heat to the condensor.Which will cause it to shut down on high heat.
So i would start with a new fan motor.Your local heating and cooling supply house should have these in stock.
Aug 01, 2011 | Heating & Cooling
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
Jan 25, 2011 | Whirlpool GS6NBEXRS Side by Side...
So-low freezer try to start, but stops after a second
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Oct 23, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Ruud UAKA042 Air Conditioner Logo
125 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
