Question about Refrigerators
I have a water buildup problem on the bottom shelf of my sub-zero 550 r Ref . The door seal looks good but every few weeks the water starts to buildup and run out the bottom of the door onto the floor .
The water should drain underneath and be evaporated by the compressor heat. Sounds like the drain is plugged. There should be a drain hole in the bottom you may have to pull out a plug like thing. Flush out the hole with hot water using a turkey baster. Pour a mild bleach solution down to kill the remaining mold. Empty the drain pan underneath.
Posted on Jul 03, 2008
I have a Sub-Zero 550 bottom freezer Ref. It is leaking water all the way back & center beyond the drip pan. I have disabled the ice maker by removing the ice bin and it is still leaking water. I...
There is usually one hose and it could have been moved so its not in the pan any more, you should be able to see it near the pan, from the front with the grill removed, use a coat hanger and hook it back into position, if the pan is over flowing, than that's another problem
Jun 26, 2011 | Sub-Zero Bottom Freezer Refrigerator
Drain tube apparently doesn't allow condesate in ref to drain out
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a sub zero (model 550) bottom freezer. Moisture appears to gather at the right side of the freezer then ices up to the point that the drawer can not be opened. I have replaced the drawer seal and...
I had this problem several times and have learned alot. Hopefully some can benefit from my learning and mistakes.
On the inside of the freezer on the right is a drain tube. The defroster cover flows into this little drain. This drain goes into the pan at the bottom of the freezer, and the water evaporates. My subzero 550 had an old drain heater already in there, but obviously not working properly.
First, defrost the freezer completely. I had also poured hot water down this little tube, but this takes too long, and doesn't clear the drain completely. Also, see if you can tolerate turning the freezer temp setting down. I had mine at 1, and it was sufficiently cold. With this simple method, note the weeks /months until it happens again. If you can live with this, you are done.
If not, order a drain heater (contact Clarke Customer at 800-305-0722 and order item number 4202160, Freezer Drain Heater - under $40). I installed this and got some success, and am still counting the weeks after 8 have already passed.
Good luck
May 16, 2010 | Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Ice build up behind the veggie drawer. My 550 is 13 years old. This always starts with the warm, humid weather, but this year, it is not improving as the weather turns colder. Any advice? I can't open the...
sub zero are vey expensive, and sometimes tough to diagnos, but judging by your description, i would inspect your door seal, make sure it is closing and former a good seal all the way around
the best way to handle this, is to turn it off for the day, and let it defrost for 24 hours,
Oct 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Jan 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Z 550 reidge internal leak
The tube behind the crisper drawers is not insulated well enough and will repeatedly freeze, leaving the water to drain on your floor. The solution is to thaw the tube and put a piece of copper the length of your tube, into the area below. The wire extending into the area below is just warm enough to keep the tube from freezing.
Aug 19, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
