My brother MFC-420CN won't print, I checked for any foreign obstacle, MFC. my name is Steve.
  • Anonymous Apr 15, 2009
    I CAN NOT PRINT ANY THING FROM MY COMPUTOR, I HAVE GONE THROUGH ALL SUGGESTIONS IN THE MANUAL AND CHECK THE INK WHICH IS ALL FULL . SHIRLEY
    Genius:
  • 2,785 Answers
Plz try by reinstalling the drivers for the printer, check the status of the ink level, try by changing the usb slot and cable
Posted on Jul 03, 2008
Won't print cyan color
try reseating the magenta ink cartridge or replacing it.
Jan 21, 2013 | Brother MFC 420CN All-In-One InkJet...
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
Will not print. in window it says "unable to clean MFC-420CN" see trouble shooting and routine maintence. How do I fix this problem I no longer have a book with this fax printer machine.
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
Check the brother website to find a service center in youre area.
Apr 10, 2010 | Brother MFC 420CN All-In-One InkJet...
Display says: unable to clean refer to Maintenance Chapter of users guide (which I cannont locate) Printer is not printing,faxing, nor copying because of this.
acorn gifts --
Here is at least a start to your solution... the Brother site for your printer is here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=mfc420cn_us&c=us&lang=en&flang=all
Which has the download for the actual manual (in PDF) here (you can right-click and "Save Target As" to save to your computer, or open it directly):
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Section 11-4 (page 123 of 200) refers to multiple error messages that will halt printing (including "unable to clean"). There are also a few pages following (to section 11-8, page 127 of 200) that give detailed illustrations of how to remove jammed items etc. from the unit.
In the end, the "cause" according to the manual is:
problem.
OR
... if there is paper jammed, you have a shot at fixing it yourself!
I hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 19, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Unable to clean code shows on display
Hi there
This is usually caused by one of the following:
problem.
—OR—
If you go to page 11-4 on the following pdf download, it will document what steps to take to resolve this issue
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
Hope that helps,
Take care,
Michael
Nov 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to print
See Mix it Up's posts, he has covered this subject on other simular models very well,
http://www.fixya.com/support/t226406-keep_getting_message_unable_print_see
Nov 11, 2007 | Brother MFC-5440CN All-In-One InkJet...
jasbo
jasbo
