My zune just died it will not turn on or nothing only had until christmas of 07. i can't reset it nothing happens.
  • frankmpayne Sep 18, 2008
    my zune turn off and will not turn on
My name is frank. my zune turnd off but it will not turn on. the battery is full and i tride everything.
Posted on Sep 18, 2008
    my zune will not turn on
120gb Zune won't turn on or charge
No probley not it needs a new battery more than likely they can be bought for around $25.00 or so no fun to put in very delicate.
Sep 29, 2017 | Microsoft 120gb zune digital player /...
My Zune wont turn on
Press up and the back button at the same time for about ten seconds. This should reset your zune.
Jun 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
8 gig Zune won't turn on!
Possible defective/open battery circuit.
May 21, 2017 | Microsoft Zune JS8-00001 Digital Media...
My zune won't turn on
Check the Lock button. Push it all the way to the right, then all the way to the left. I'm continually having to do that w/ mine, even when the orange Lock symbol ain't showing.
What do you mean by "tried to reset it"? By holding the Back button (on the left) and pressing the top of the Control Pad until you get the Zune logo?
Try these steps. They may work.
Mar 04, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune wont load
This is how this problem should be resolved:
  1. Disconnect your Zune from USB and AC power sources.
  2. Because the player is frozen, its battery will drain—this is good. Wait until the battery is empty and the screen goes black. If the battery was fully charged, this might take a couple of hours.
  3. Wait until after noon GMT on January 1, 2009 (that's 7 a.m. Eastern or 4 a.m. Pacific time).
  4. Connect your Zune to either a USB port on the back or your computer or to AC power using the Zune AC Adapter and let it charge.
I cannot believe the savvy programmers for Zune did not identify this problem in advance
Jan 08, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune froze from using the wrong charger
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 01, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
ZUNE NOT WORKING! ONLY BLACK SCREEN! WONT CHARGE!
Listen everyone this is what happened to me and what I did. Let the battery drain completely (unplugged from computer). It usually takes 5 to 6 hours to drain completely.
Then plug back in and hold the back and down button at the same time. Zune should resume functioning afterwards. All that is needed is a recharge.
Dec 29, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune stopped working and now will not turn on
I figured out the solution by just getting upset.
Hold the Back arrow (<-) and Up on the touch pad and it will restart the Zune. This works for the 8gig and 80gig Zune.
Oct 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Reseting my zune
Hold power slider for 10-15 seconds.
User's manual/help here:
http://www.zune.net/en-us/support/usersguide/default.htm
Apr 07, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
141 people viewed this question
 Grubhead
Grubhead
