Question about Samsung SGH-D900 Cellular Phone
Locked fone i did the same thing i pushed the nam 2 and than i went to the metro store and they changed it back ta nam 1 butmy passcode still dont work for my fone so is there sumthin else i can do cuz i tried the code u posted and it didnt work
    Brigadier General:
  • 7,752 Answers
You need to press *2767*3855#
Posted on Jul 03, 2008
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
I changed over to other nam and powerd down phone
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878#
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert only a half of it,
Very important so it won't ask for network password and shows "Insert SIM" message.(possibly in a different language)
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.push the sim fully in at this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset: *2767*3855#
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
7. Now Disable network lock By typing: #7465625*638*00000000#
Phone is unlocked
Mar 06, 2010 | Cell Phones
NAM 2 unlock code
I did the same thing... I found this & IT WORKED!! the URL is http://www.blurtit.com/q1652331.htmlit's super easy & only takes a second to do. Hope this helps. Blessings. -~myleshigh
Jan 01, 2010 | Samsung Sway SCH-U650 Cell Phone
I clicked the namp2 thing and now i cant get it unlocked
If your phone is set to lock, and you have changed the Nam, you will have to take your phone to your provider so that they can read the lock code for Nam 2 and change it back to Nam 1. You may want to call them first, they might have a standard code that they use.
Dec 01, 2009 | Samsung Hue (SCH-r500) Cellular Phone
I have a sch U740 samsung phone nam 1 code
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
Jul 09, 2009 | Samsung SCH-u740 Cellular Phone
Locked out
Try 0000 as the passcode. That is the only other default password unless it was changed or there is a corrupted file in the phone.
Nov 03, 2008 | Verizon Communications Verizon Wireless...
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Samsung SGH-D900 Cellular Phone Logo
67 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
