A/C does not blow cold air. It has frosting built on the pipe that connects to the a/c unit outside. There is some water built up where the filter sits. I turnd off the a/c for a full day, the frost melted, filter is very clean, and nothing on the inside seems abnormal. I started the a/c again after 1-day but the frost started to built up again and no cold air was blowing. (it blew cold for a few minutes only). I don't know what the problem can be. Please let me know if you have any ideas to make it function correctly again. Thank you, Shelly
  • pikecho Jul 04, 2008
    Chillmaster,
    Thank you for your answer. I have an appointment with a technician to come and take a look at it. Hopefully he can tell me how did the AC ran low in freon since it is only 3 years old and it has always been kept clean.
    Thank you again for your honest efforet and help. It is greatly appreciated.
    Cheers,
    Shelly
    Scholar:
  • 104 Answers
Shelly,
Most likely you are low on freon. Your air conditioner uses a coil that gets cold when the freon passes through it to produce your cooling. The temperature of the freon inside the coil is directly controlled by the pressure of the freon. When the system is low on freon, it causes the coil to become to cold and then instead of sweating it freezes. You will need an a/c technician to reslove the problem for you as the task requires tools and equipment that you most likely don't have.
Thank you,
Chillmaster
Posted on Jul 03, 2008
Which is cold water connection on the boiler
Incoming cold water usually connects to nipple marked with C, and/or the nipple that feeds into water filter (if unit has built in filter)
If unit has shut-off valve, then shut off is located on cold line.
If unit is operable, then turn on hot water and see which pipe gets hot ... and then cold is other pipe.
read your product manual.
Search your brand and model on internet to locate product manual.
Otherwise re-post question and include brand and model number so product manual can be located and information can seen first-hand.
Gene
Jul 18, 2013 | Water Heaters
Blow air running compressor not running
Your air compressor is dead or the refrigerant has leaked out. Wait!!! Don't give up yet. This very same situation happened to me. I had air blowing(not cold at all) but the outside A/C compressor was not running. Check your inside unit which is either in a closet or in your attic. There is a water pan underneath it. If it is full of water, it has activated a floating shut-off switch that is wired directly to your outside Compressor. You must remove the water. the best way is with a large wet-dry vac. Then make sure the drainage pipe is properly connected and is not clogged. You can probably fix that by sucking out the drain pipe with your vacuum. Once the water is gone, your floating shut-off switch will re- activate your Air Conditioner. Kind of like the floating ball in your toilet. You may sweat a lot, but you will save yourself a service call and some big bucks. Good Luck!!!
Jul 22, 2012 | LG Heating & Cooling
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Air conditioner not blowing out enough cold air fan is working but frost is built up outside and in on lines
Sounds like the unit may be Short on refrigerant, the frost can be sign the refrigeration is taking place on the pipework between the indoor and outdoor unit and not on the internal coil (evaporator indoor unit)
All the best
Jul 05, 2010 | Heating & Cooling
Our AC unit stopped blowing cool air. The Unit runs but no cold.... We just changed the filters a month ago. My wife swears she hears a beeping tome every couple of minutes. The unit is a CPLE 30-1C????
if you have not clean the outside unit,,and it is dirty will not breathe right and cause the air to be warm try this,, mix clorox and water into a sprayer,cut unit off clean coils good.hope this work for you,,one thing to check before you clean the unit,,while it is running go out and look inside the unit if you see ice on pipes you are low in gas !
Aug 11, 2009 | Heating & Cooling
Split Air Conditioning problem
are you sure it is the liquid line and not the suction line? The small line or the big line. should not have frost on the small line or liquid line. Frost normal on the insulated big line.
Aug 09, 2009 | Heating & Cooling
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Leaking air conditioner unit
I suppose that the water is coming from the unit where the blower motor is. Condensation is created by the evaporator coil while its running and is suppose to drain into a pan under it and through a pipe to the outside. This pipe could be stopped up. The easiest way to fix that is to blow air through the pipe from the outside. It probably comes out close to the outside unit. It could be that your inside filter is dirty causing reduced air flow and making the evaporator freeze too. Change the filter. That may help. There are other steps that you could take if these don't help. Contact me by email if you need to. Cant run over there because I'm in Missouri but may be able to help in a chat room. kstfas@yahoo.com
Aug 15, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
