Question about Philips 60P8341 60" Rear Projection Television
No sound from a Philips model 60P8341...
I have a Philips 60P8341 TV,.video is fine but there is no audio from the internal speakers. I do get sound if I connect speakers to the headphone jack.
    Genius:
  • 1,139 Answers
Hello Jarvis1,
This is an indication that the actual sound output is working, but the amplifiers to the speakers are not. How you could take care of this is to check in there are any loose connections to the speakers. Then check if you have sound coming from the leads of the output stereo amplifier (You will need the schematic and an audio tracer/tracker to find this location and test for sound). I would venture that there would be no sound from the amplifier. If not you will have to replace the amplifier chip. I would suggest getting a qualified TV technician to perform this task. If you do have sound at the output of the strereo amplifier chip, then it might be a case of the earphone jack switch being broken, let me explain when you plug in your earphone the speakers are disconnected by a switch in the earphone jack if this switch is broken it could disable the speakers and produce these results. There is also the possibility that you have the speaks disabled from the menu of your TV (check this too, actually check this first).
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 04, 2008
My Philips Magnavox 60 in rear projection TV # PTV775-AH01 has no power when you turn it on. How can I fix it?
It sounds like a power supply problem, it could be as simple as an internal fuse (not the fuse in the plug) or something more sinister like a transformer issue which can become expensive, either way i wouldnt recommend repairing yourself unless your confident with electrics and know what to look for
Oct 28, 2014 | Philips 60P8341 60" Rear Projection...
Can't get sound out of Boston soundbar when hooked up to 46" LCD Philips? Soundbar works fine when hooked directly to iPod.
You may have to go into the settings on the tv and turn off the internal speakers in order to get audio out of the jacks on back.
Dec 27, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
No audio out connecter on back of Phillips 52 in TV
Hi and welcome to FixYa,
Almost all (European) Philips have a SCART type connector as shown below.
With the use of a SCART Adapter (below), the outputs are available as Audio L/R & Composite Video and S-Video either as output or input.
Good luck and thank you for using FixYa.
Feb 09, 2009 | Bose Cinemate Digital Home Theater System...
Sound
check for bad solder at the audio output IC and the speaker plug connector
Sep 01, 2008 | Philips 60P8341 60" Rear Projection...
Philips big screen tv
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
PHILIPS 60P8341 PROJECTION TV NO PIC NO SOUND
Thats the DPTV 300 series phillips HDTV its definatly worth fixing. How are your troubleshooting skills. Sounds like either a problem in the LSB or SSB circuits boards. On our website we have replacment circuit boards for that model. Our prices are less than half what others are getting. Let me know if you would like me to post a link, we also have the service manual for your model.
Mar 08, 2008 | Philips 60P8341 60" Rear Projection...
60" philips projection tv
HI I AM HAVEING PROBLEMS WITH THE VOLUME THERE IS NONE AND NONE OF THE BUTTONS IN FRONT OF THE T.V ARE WORKING HELP PLEASE
Mar 07, 2008 | Philips 60P8341 60" Rear Projection...
No sound
check your remote to see if it's on mute...or mute is enabled...check your connections from the tv to the cable box...if your using surround sound...check those connections as well...if you have a dvd player..hook it up to the tv and see if you get audio...let me know if this helps...if not i will give you more things to check
Feb 07, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
