Question about Mitsubishi VS-50609 50" Rear Projection Television
No picture or sound
The set turns on, but no picture or sound. using the remote and pushing the input button, it goes throught the various inputs but still no sound or picture on any input channel,, a few times before the no picture or sound, the set came on and the picture was very wavy
  • Anonymous Mar 27, 2009
    No picture, no sound. Just a blue screen that says the input in the upper left corner with s vid
    President:
  • 357 Answers
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later, it fixed the intermediate problem of no video, when turning on the power.
Here is a picture of what they look like:
Thank you for using FixYa. Have a nice day and please remember to rate this solution as fbe0a70.png if it helps you.
If you have anymore problems please ask me!
Thanks
Dustin Ellse (BearWeb)
Posted on Jul 03, 2008
I bought this tv mitsubishi vs-50609 its a 2002 year and after a few years like in 2007 when i would turn it on it would be snowy and static and then after a while the picture and sound would come on then it would take even longer as time went on to get a picture and sound.
Posted on Nov 25, 2008
    New Friend:
  • 129 Answers
Convergence ic's need to be replaced included some associate resistors part # stk 392-120, iparets can be ordered at www.partstore .com
Your rating to my answer is highly appreciate
My dog stepped on my entone urc plus. I can still pull up the guide and select channels (the stb button lights up) but there is picture or sound. Help!
It sounds like the tv is either set on the wrong input of the tv (check the back of the tv set and verify the input number) then use the remote's input button to change to that input number, OR the tv is not set to channel 3 -if using a cable box!
Good Luck!
Rich Lilja
Jan 05, 2014 | Televison & Video
I am currently house-sitting for a family friend. Watching TV last night, the family pet jumped on me, causing me to hit the knobby button between the menu and reset buttons on a sony universal remote,...
This universal remote (or the TV's original remote) should have an Input button, which allows you to switch the various inputs available on the TV (such as HDMI, composite, over-the-air, cable, etc). You can try hitting Input until you see a picture, but be sure to turn on any devices connected such as set top boxes, DVD players, etc.
Mar 04, 2011 | Sony Televison & Video
When the tv comes out of standby the dtv logo appears but then the screen goes black and there is no sound
Most likely you have changed the input setting for the TV, on the remote or tv there will be a button that is "Source" or "Input" or something along these lines which allows you to switch through the various settings, one of which will be the one you are used to seeing when you turn on your tv.
Mar 01, 2011 | Televison & Video
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
When I turn on TV I get a message no video input. We never use video with this tv. Only have it for looking at satelite. The other main tv is working fine. I pressed all the buttons but nothing works.
Sounds like the input accidentally got changed. On the remote that came with the TV, push the INPUT button until you get your satellite picture again. If your SAT. remote is programmed to your TV, push the TV button, then the input button until you see your picture. If this doesn't work then the sat. cable is not securely attached or no longer works.
Aug 30, 2009 | Philips Magnavox 27MS343S 27" TV
No signal
you have to take the remote, find the input button, push the input button untill your picture comes back, you should see the input go from cable/antenna, to vid 1--vid2---vid3---if pushing the button a couple of times dont change it, you will have to hit the input button, then arrow down, and select the nexy one, do that untill you find the picture
Jan 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
Not being able to change inputs
Change the input setting on the tv not the remote.
If you are using a universal remote it may not be programmed correctly.
When you push the input button on the remote it is changing it to the Over The Air Antenna, it is not recieving a signal and there is no channel label added for the station it is set to.
If you do have an antenna connected, from the menu do a channel search and see if it can find any signal.
Let me know how it goes, I can assist further.
lone99star
Jan 09, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Running my tv throught my vcr but have no picture only sound
You don't say what kind of tv,model,etc. or if the tv tuner is 'solid state', push button, knob type channel changer.
If you REALLY, REALLY have to use the tv through the vcr.place the signal [antenna, cable box, cable antenna (signal) in vcr RF input.place a blank vhs tape to record, use the RCA jacks[AUDIO & VIDEO] in back of the VCR to INPUT of TV video & audio ( if you have then ) While you are recording, you will be able to see the tv program.
p.s. place the TV\VCR switch to vcr.
Dec 14, 2008 | Televison & Video
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Mitsubishi VS-50609 50" Rear Projection Television Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
