Question about Lexmark X5150 All-In-One InkJet Printer
Printer Problems LEXMARK 5100 Series - 5150 model
I want to reset printer default settings to original settings followed instructions, it said printer settings were locked. How do I unlock? How do I get rid of separator sheet?
    Genius:
  • 1,847 Answers
This link will help you ...
http://www.lexmark.com/publications/pdfs/techref_WB.pdf
Thanks for using Fixya
Posted on Jul 03, 2008
Hello. pls let me know how to restore my lexmark x6500 wifi printer??
To restore your Lexmark X6500 Series printer to its factory default settings, follow the steps below:
  1. Press the Settings button on the printer operator panel.
  2. Use the arrow keys to move through the selections until Defaults is displayed. Press the check mark button to accept this option.
  3. Use the arrow keys to move through the selections until Set Defaults is displayed. Press the check mark button to accept this option.
  4. Use the arrow keys to move through the selections until Use Factory is displayed. Press the check mark button to accept this option.
  5. Use the arrow keys to move to the required country, language, date & time, time format, fax number and fax name and press the check mark to confirm each selection.
  6. When the process is complete, the display will read Initial Setup Complete.
Source: How to Reset a Lexmark X6500 Series Printer to the Factory Defaults
To reset the printer's wireless network settings, please refer to this article: How to Reset the Network Settings on the X6570 Series AIO Inkjet Printer
Jul 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
I have a green Wi-Fi indication of the from of the printer, but it won't print. it says... Lexmark 3600-4600 series 3A82A0_P1
Try to unplug then replug the printer into the power source to reset it. This usually fixes minor communication issues. If problem continues, try to print the wireless network settings to check if your printer is still connected to the same network as your computer(s). Follow the steps in this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If not in the same network, you may need to reset the printer. Follow the steps on how to reset the printer wireless network settings: How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. To reconfigure printer back to your wireless network, refer to this article: How to Install the X4600 Series on Wi-Fi Network - Infrastructure Mode.
Apr 20, 2011 | Lexmark X4690 Wireless InkJet Printer
Need to re-install Lexmark 5150 series printer to Dell computer but no 5100 series listed on computer installation screen. Is there a compatible series that I can enter to connect my 5150?
Download and follow instructions from lexmark web site: http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_UK&locale=en&productCode=LEXMARK_X5150&page=product&frompage=null#1
Good luck
pls. vote so I may continue sharing
Nov 10, 2010 | Lexmark X5150 All-In-One InkJet Printer
How do i reset my wireless printer? i cannot reconnect to it seems the printer cannot connect to the wifi network
Here's an article found in the Lexmark website on How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults. Just click on this link: http://bit.ly/aePRSr. Follow the instructions carefully. Hope this helps.
Jun 21, 2010 | Lexmark X4650 InkJet Printer
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Oct 01, 2009 | Lexmark E260dn Laser Printer
I need driver for my printer.Model #X 5150. I loss disc instalation.thank
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,find thefile,double click on the file, then if you get introubles,follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Oct 17, 2008 | Lexmark Office Equipment & Supplies
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Driver downlod
hmmm..which Operating system are you using?
got backup?
Feb 11, 2008 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark X5150 All-In-One InkJet Printer Logo
396 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
