My mp3 reads to, 'Please format the payer with your PC'
    Genius:
  • 1,847 Answers
Pulge in the player to the computer through the USB port. click My computer... you will see a new drive there...right click and format...
Thanks for using Fixya..
Posted on Jul 03, 2008
My computer asks me to format whenever i try to connect my mp3 payer through usb... when i try to turn it on it shows ERROR! REFORMAT INTERNAL MEDIA FAT16... even my micro sd card is not...
in this case you gonna have to format your microSD card either from your pc or your player. and if you still wanna have the data you had before you may consider recovering those data using a data recovery software but that doesn't mean you can get all the data you had before. recovered data can be corrupted or partially lost. but you can try this method.
Jun 23, 2011 | Computers & Internet
Trio v430 is not recognizing my expansion memory card unless I remove and reinsert it each time I turn it on.
In this case I'd suggest that you format your player. Contents may be removed by using this function. So make sure to back up your contents. You can sync your player with Windows media payer version 10 or above.
Here is how to format it:
1. Connect the MP3 player to a working USB port. Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending on your system configuration.
2. Right click on the removable drive icon which is your player's icon and select format from the drop down menu.
Your MP3 player will now start formating. Follow onscreen instructions and disconnect when format is completed.
Hope this helps.
Mar 18, 2011 | Mach Speed Trio V430 MP3 Player
My mp3 player is not getting on.
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Also, when you format the player make sure you use FAT32 & not just FAT. Otherwise you will not be able to transfer files to it.
Apr 08, 2010 | Transcend T.sonic 610 MP3 Player
My Dvd payer keeps telling me to check the disc,
If it is a commerical disc then your laser may be going out...if it is a material that was burned on a blank disc it might be formatted incorrectly for your player.
Oct 01, 2009 | Televison & Video
My comuter won't recognize my motorola ve 240
i use the memory card with out the phone and open the folder for it. Then i just drag my songs into the music folder that way. It works with pictures as well
Feb 09, 2009 | Audio Players & Recorders
On my matsui MP3 player
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Apr 12, 2008 | iLO (2 GB) MP3 Player
NEED HELP!!
format your mp3 using the system from your mp3 then download the sonique stage to enble your mp3 songs and to be save
Jan 01, 2008 | Sony NW-HD5 MP3 Player
29 people viewed this question
 Grubhead
Grubhead
