Question about Panasonic NV-GS11B Mini DV Digital Camcorder
Recording From Underwater Camera
I am trying to record from a Aqua-Vu underwater camera to the NV-GS11GN, When I hook up the camera I can see what the underwater camera sees but I cannot record anything, When I switch it to record it makes the underwater camera flicker and wont record, any advice
I have a gs11EB. I don't it's possible to record into this camea from an external source?????
Posted on Aug 27, 2008
How do I get battery cove open?
Seems like others have the same problem. Push and hold the latch and then slide the cover outwards.
There is a video here
SVP Aqua 5500 How to open battery compartment for SVP Underwater Camera
May 05, 2016 | SVP Aqua 5500 18mp Underwater Digital...
Can't see video from intova SP1
For SP1, please use micro SD card up to 32 GB that is class 10 if you want to record 1080p HD video. If you are using a class 10 card and you still cannot view your video, please be sure that you have the H.264 video codec in the video player software in your computer. Also, be sure your computer is compatible with HD video. It should be running either Windows 7 or 8 if it's a PC or OS 10 or higher if it's a Mac. If you are using a class 10 card, have H.264 codec and compatible OS on your computer and still cannot see video, then the camera may be recording corrupted video files in which case, please contact Intova directly by email: or call us at 808-837-0074 for customer service/warranty coverage. Thanks
Aug 08, 2013 | Intova SP1 Sport Pro 12.0 Megapixel,140...
I am having problems introducing the SD card into my SVP Aqua 5500
The camera takes microSD cards. Open the battery door to uncover the slot.
Feb 25, 2013 | SVP Aqua 5500 18mp Underwater Digital...
My aqua wp6800 camera will not download pictures to the computer
Did you try inserting the micro SD card into the PC? You can buy a micro SD to SD adapter then just get an SD to USB drive to easily move files between micro SD and PC assuming the USB cable isn't working for whatever reason
Jan 20, 2013 | SVP Aqua Wp 6800 Underwater 18 Mp Digital...
Is canon ixus 50 is waterproof?or can use underwater?
No, the IXUS 50 is not waterproof. You cannot use it underwater without an underwater housing.
May 12, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
No, the IXUS 50 is not waterproof, you cannot use it underwater without an underwater housing.
My camera microphone is bad quality??????
Mine does that too! Idk, i guess it's normal. And I kinda hate it. I'm looking into buying a flip for videos. I guess theres an underwater case, so you could use that for undeerwater videos.
Apr 08, 2009 | Olympus ? 850 SW Digital Camera
I cant figure out how to record off the TV or VCR
Hi, you should setup analogue in function.
Page 93 on user's manual.
After that press REC PAUSE on camcorder and start your VCR or underwater camera.
Nov 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Aqua vu underwater camera
i figgured out how to fix it. i was having the same prob. so i cut the male conector part off the the camera cord and cut like 4" of the black cord part off to expose the wires. there will be 4 colored wires and 1 bare wire cut the bare wire off as close as you can to where you stripped off the black part, then expose the top inch of each color wire. OK now open up the back of the monitor, take the black female connector off you dont need it. you will see a 4 prong female connector part inside cut that off too, then conect the wires black - black / yellow - white / red - orange (i think it was orange) / blue - green . it sounds kinda complicated, but really easy, and now it works great! make sure you use electrical tape or something over bare wires
Aug 09, 2008 | Aqua -Vu Perch Underwater Camera with...
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
Panasonic NV-GS11B Mini DV Digital Camcorder Logo
170 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
