Question about Sony KP-51HW40 51" Rear Projection Television
Green picture why is it showing bright green only? toshiba 36a50 model
    Problem Solver:
  • 30 Answers
Your red and blue cables are unplugged from either the source or at the tv.
Component video uses a red green and blue signal. If the red and blue are pulled you will onle see the green. If the green is pulled you will see nothing.
Check your cables 9 out of 10 times its a loose connection or bad interconnect cables.
Posted on Aug 01, 2008
Toshiba, 36A50 picture is a thin white line. Can this be repaired?
Yes...this TV may be repaired. The line you describe is in the center and is horizontal across the TV. You will need to resolder the vertical IC pins. This vertical IC is mounted on a large heatsink. Under the board you will see there are 5 or 7 pins that will have rings around them. Resolder these. And you should replace two or three capacitors that are next to this IC. A bad cap will overheat an IC and separate the solder grounds. If you can find my expertise page on this website, you will see the repair in more detail. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Toshiba 36A50 36" TV
TV screen has a blue hue all over it
this problem can occur due to problem in different locations inside the tv.
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Toshiba 36A50 36" TV
36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Dec 13, 2008 | Toshiba 36A50 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
36" 36a50 tv won't turn on
My 36A50 suddenly shuts off losing audio and video. The red light on the on/off switch continues flashing until the set is unplugged.
Jul 16, 2008 | Toshiba 36A50 36" TV
Vertical size of picture
You have a number of bad capacitors in the vertical circuit. If you can solder, you should be able to repair this yourself. I'll look up your model to get the parts needed.
Dan
Jun 02, 2008 | Toshiba 36A50 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 - No Picture - Just Bright Line
THE PROBLEM IS IN VERTICAL OUTPUT CIRCUIT MAYBE DAMAGE SOLDER CRACKS
Jul 06, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 Noise Issue
your tv needs a tech the problem is in the IF circuit.good luck.
Apr 29, 2007 | Toshiba 36A50 36" TV
Sony KP-51HW40 51" Rear Projection Television Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
