Question about Relisys RLT1720 17" LCD Monitor
Monitor displays breifly then goes to blank screen
Hi, Whenever I turn on my monitor it displays the computers output briefly (~half a second) before going blank. I have tried the monitor on two other computers with the same result so it is definetaly not a computer problem. The power light on the front of the monitor stays green when the screen goes blank. Whenever I turn the power off and back on again the exact same thing happens. Help please!! My screen goes blank after about a minute.
  • ottace Sep 12, 2008
    screen goes black after a second. when i turn off the monitor and turn it back on it displays for a second then goes black again
    Guru:
  • 859 Answers
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Posted on Jul 03, 2008
  • Glenn Rogers
    Glenn Rogers Jul 03, 2008
    having said that you could leave it unplugged for a few hours and try again, but I doubt that will solve anything. give it a go though.
SOURCE: problem in monitor
I had the same problem. I found recommendations here and on other sites that I needed a new backlight inverter / power supply. I found exactly what I needed at this site: http://www.lcdrepair.us/ part number: E173FPCPWR. The have pictures of the exact card you need you need to by. Mine cost $50 plus shipping ($14.69) (ugh!) I just installed it today and it's working great. You need to feel comfortable popping the back of your monitor and working with little screws and connectors. You may find the part cheaper online. Sure beats buying a new monitor.
Posted on Apr 13, 2007
SOURCE: Monitor displays breifly then goes to blank screen
Hi, I have the same problem, I have also tried with differents OS with out any improvement. What I do now and works is when the monitor is working I play a video/movie and let it run in the background with muted sound, I works good, never turns blank whit this trick,I Use Totem player on Ubuntu (Linux), but it might work with other players and platforms.
Posted on Feb 25, 2008
I found a bad 25V 1000uF Cap in my monitor and for $2 from Radio Shack I replaced it and it is working fine now. Thanks for your help.
Posted on Feb 29, 2008
Mark_Webber
  • 472 Answers
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Posted on Apr 11, 2008
Mark_Webber
  • 472 Answers
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Posted on Apr 12, 2008
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
F1 = Fuse 1
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Problem in monitor
Sounds like the inverter board or lamps are bad
Feb 26, 2007 | Dell E173FP 17" LCD Monitor
Relisys RLT1720 17" LCD Monitor Logo
976 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Marcin
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
