SOURCE: My Garmin nuvi 205 will not give voice prompt
The germin nuvi 205 can be pre loaded specific data on the route and has voice. i dont know if yours has been pre loaded, with 3.5 navigation data.
SOURCE: Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
SOURCE: garmin nuvi 200w will not power up
if charger works then two things left bad connection or send to factory to get repaired
SOURCE: Garmin Nuvi 265w voice command stopped working.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If you are not receiving any
sound on your Nüvi 2xx the first thing to check is that the sound is not muted.
To ensure that your units sound is not muted please perform the following:
If the mute button is not ‘ticked’,
you will need to change the voice to ensure that the preset voice is not
faulty:
If changing the voice is not helping you will need to ensure that you are
running the latest software which can be done by installing a program called
WebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the software
successfully installs.
If after following all the above the final steps would be to perform a master
reset:
Note: A master reset will erase all waypoints or favorites and will restore
your unit to the default factory settings.
The device will automatically reset. Please follow the on screen prompts on the
nuvi and when completed place your device in an area with a clear view
of the sky until it acquires satellites.
SOURCE: Hi, i need to do a "Hard reset" in my Garmin nuvi 1490
power the unit on and immediatly place your finger in one of the corners and hold it there. I believe it is the top right but if it doesnt work the first time try a different corner. This will reset the entire device and erase all settings.
