Question about Nextar MA566 MP3 Player
IDK? I have a nextar mp3 and i plug it into the USB port the blue light comes on but doesn't read on the computer what should i do?
    New Friend:
  • 127 Answers
This means the driver isnt installed for the device.
first, try plugging it in, then goto my computer and look for 'removable device' that is where you will access the mp3's.
If all else fails, google 'nextar mp3 player driver'
good luck :D
Posted on Jul 03, 2008
My nextar mp3 doesn't conncect
Talked to a nextar rep, if windows doesn't load the drivers, then their is something corrupt in the firmware. When I hook mine up it keeps connecting and disconnecting. So it's most likely a firmware issue that has to be fixed by nextar.
Nov 11, 2009 | Nextar MA933A MP3 Player
I have a 1GB Nextar MP3 player that's only been used a few times. I loaded the driver in my computer. When I plug the device into to USB port, it says unknown device and I can't load any songs from my...
You need to install it as a usb mass storage device. by doing this just plug it in, and when it comes up at unknown device. right click on 'my computer' then select 'manage' this will open up the computer management window. Click on the 'Device manger' you will then look for your nextar mp3 player device, it will be marked as audio device with a yellew question mark by it, just right click that icon, select properties -> select the driver tab-> click on the update driver -> select the 'yes, now and everytime I connect a device' radio button. click next. select 'Install from a list or specific location (Advanced)' radio button. select next, on the next screen, select 'Dont search. i will choose the driver to install' button. Click next, you will see a list of devices on this screen, you are going to select 'USB Mass Storage Device" then select next. At this point you will see the drivers being installed. After that you will be able to use your Nextar MP3. Just click and drag your mp3 from your pc to your nextar.
I hope this helped.
dont forget to vote!
Aug 14, 2009 | Nextar MA933A MP3 Player
Reads "No File" even thought there are files on it.
I just had the same problem. Go back to your menu, make sure you are on your play music icon and instead of clicking on the center button with play and pause on it click on the menu button again to make it access the folder. You should see the word music come up across the screen once it's chosen.
good luck!
May 30, 2009 | Nextar MA566 MP3 Player
Nextar MA 166 MP3 Won't Charge
You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
-Tha Mp3 Doctor
Jan 24, 2009 | GPX ML648B MP3 Player
Nextar digital mp3 player
how do i put music into my mp3 player?
Jun 26, 2008 | Nextar MA933A MP3 Player
Nextar MA566
reformat your unit .... and download a new files of music
Feb 23, 2008 | Nextar MA933A MP3 Player
Driver installation
nextar.com then support section u can chose ur player and downlaod drivers
Dec 22, 2007 | Nextar MA933A MP3 Player
Recharging?
This product uses a built-in rechargeable Li-ion battery which is charged by usb power. So when you plug it into your Computer or Laptop it recharges with the power it get through the usb port. You can also buy a USB AC Charger for MP3 Players it plugs into your wall outlet and has two usb ports on the bottom to plug into. You can get on at Walmart for about $15.00 called MusicPower
Duet:
http://www.walmart.com/catalog/product.do?product_id=5750794
There are even USB Charger for you Car as well.
Charging Section of the User Manual
This icon will be displayed at the upper left corner of the screen. The following pictures indicate the
charging status of the battery:
(1) When the battery is charging, the battery icon will be changing from an empty battery to a full battery icon to indicate the process.
(2) The following icon will replace the charging one when it is full but the power supply is not being cut off. Which is a Battery Icon with a Lighting Bolt in the center of the icon.
(3) The player will automatically shut off when the power is used up. In this case, all setting will be
saved.
You can get this information on the Nextar website below and the right hand side there section call Downloads click on the MA715.pdf.
http://www.nextar.com/frontend/proddetail.asp?pn=MA715&co=10000309
Later
Nov 16, 2007 | Nextar MA7151B MP3 Player
Nextar MA566 MP3 Player Logo
159 people viewed this question
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
