Question about Toshiba TN61X81 61" Rear Projection Television
Toshiba TN61X81 Convergence
I have the same problem with blue convergence - no horizontal movement. How did you solve the problem? Part replacement? How many $?
Need to know generic number of convergence output IC's.STK392-100,or what,Please
Robert: robert19972@aol.com
Posted on Apr 03, 2009
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
Toshiba TN61x81-- after convergence IC's replced
Please don't be offended by my suggestions if you are experienced at circuit repair.
You may have a cold solder joint or bridged joint. Check and re-check your connectors for placement. It is normal to have to adjust the convergence and focus after replacing the IC's. There should be a row of focus knobs (ususally covered by a piece of black tape) with the screen controls.
The convergence IC's won't affect the visibility of a color only the alignment.
Sep 21, 2009 | Toshiba TN61X81 61" Rear Projection...
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
Blue convergence failure.....
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Convergence problem Toshiba tn61x81
You need the original remote control to adjust the convergence..If you tried the original remote,and still have that problem,I would advise you not to spend another dime on it...You can shop around and buy a new big screen tv with 3-5 year warranty,and less headaches..Check vance Baldwin electronics in Georgia to see if they can order a remote for you..Good luck..
Oct 09, 2007 | Toshiba TN61X81 61" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Open Questions:
Toshiba TN61X81 61" Rear Projection Television Logo
202 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
