Question about Sceptre X9G-NagaIV 19" LCD Monitor
Westinghouse L2410NM monitor dead
My Westinghouse L2410NM computer monitor is dead (no "power on" LED even). There are no blown capacitors in the power supply. Warranty return is not an option. Thanks in advance!
  • Anonymous Aug 14, 2008
    had same power problems two different times took back first one within two weeks,second L2410nm lasted six moths but still under warranty they said it will be replaced ,we:ll see ! not reel happy with quality or menu functions.westinghouse has so far been cooperating well and prompt,should probablyget extended warranty on newer brands and models.
  • 4klind Feb 01, 2009
    It turned out to be a metal washer between the power supply board and the mount. I bought a monitor with a broken screen and swapped out all other electronics. It did not have the washer. I put in the old power supply WITHOUT the metal washer and it worked!!!
What about the fuse? Sometimes there is a fuse on the circuit board.
Posted on Sep 02, 2008
Hey I have the same problem and was wondering what you meant by metal washers? Like the metal coverings on the PSU?
Posted on Jun 02, 2010
    Scholar:
  • 144 Answers
Check different power cable
check different power socket
if both have no effect buy a new monitor is the only other option.
Posted on Jul 05, 2008
4 Suggested Answers
SOURCE: dead scepter x22 monitor
Had a Sceptre DCL9A model for mine. There are plastic snaps which hold the back and front covers together. After I took off the screws and detach the monitor stand, I slid a very small flat head screw driver along the sides until I found each snap. They should come loose easily with a slight twist of the screwdriver. There are about 5 on each side of the monitor (not counting the monitor). Do not try to force it as you can warp or crack the plastic.
Posted on Jul 16, 2008
SOURCE: Turn on the monitor the screen says "out of range" in a small window and turns off
Although this message usually indicates your computer is outputting too much resolution for the monitor, I've noticed that this monitor also rejects 800x600 at a low refresh rate. Using a different monitor, set the computer to output 1280x1024 or 1024x768 at 60 Hz refresh rate, then connect the DCL9A.
Posted on Jun 09, 2009
reyn8175
SOURCE: x22wg-Gamer Monitor: It appears the power supply is dead, what can I re...
you need to check if your capacitors are blown, if they are, you can replace them...it's a very economical way of fixing it. This is a common problem of Sceptre x22wg-gamer.
Posted on Jan 24, 2012
Westinghouse monitor l2410nm display comes on then dissapears
you must check the power supply board, look for a bulging electrolytic capacitor which may cause of voltage drop.
Mar 29, 2013 | Westinghouse 24" L2410nm 1920x1200 16:10...
Unable to get a picture on the monitor even though it is on
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20L1916HW/
Check the caps in the power supply/inverter board for leaking/bulging tops and bottom seals, if you have white screen , then it may have blown fuse on the T-CON board.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 10, 2010 | Westinghouse Electric L1916HW 19" Monitor
I got the westinghouse LCD monitor model L2140NM several years ago. Yesterday the monitor got hit on the screen and it does not work. How much would it cost to repair? the screen is cracked and needed to...
hi, i'm actually looking for a broken westinghouse l2410nm monitor to fix mine. if you're interested in selling yours shoot me an email at mymaries1806@gmail.com. parts are hard to find for this monitor especially the screen itself. thanks for you consideration.
Sep 04, 2010 | Westinghouse L2410NM 24 in. LCD TV
I have a flat panel lcd 19, it doesn't power on
Don't know what model you have, but I would check the fuse first. It should be marked with a Fxxx where xxx are numbers. Sometimes the fuses are glass, others times they look like little surface mount chip types. If you find that a fuse is blown, does not mean that just replacing it will solve the problem, you need to figure why the fuse has blown, typically the FETs short out. Hope this helps.
Jul 15, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Does not power up freind thinks it's a blown capacitor
Yes, it can be that and other components.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE (LCM-20V5 may be thesame chssis as yours) and monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Westinghouse LCM-19v5 Monitor
I need instructions to install L2410NM monitor came with no instructions
Here is the link to install your monitor:
http://www.westinghousedigital.com/pdf/105_User_Manual.pdf
Jul 03, 2009 | Westinghouse Computers & Internet
Westinghouse L2410NM replacement LCD panel
WDE may or may not have parts for our dead monitors. They gave me the following phone number: (562) 236-9800. I have no idea if they can look up part numbers for us if we can't locate them somehow ourselves. I don't see a service manual anywhere...
To the guy who wants to get the front bezel off: it just snaps off once you unscrew the 3 screws from the bottom on the back. I succeeded in getting all of the plastic case off, but then I was looking at potentially destroying the foil shields before getting it further apart.
Mar 10, 2009 | Westinghouse L2410NM 24 in. LCD TV
Computer monitor wont turn on
Hi there :
You may want to want to check with the manufacture but some of these have a i fusable link in them my triton had the same thing happen and i called the manufactue and got the location for it and and replaced it my self .. hope this is of some help regards mike
Feb 16, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
The screen comes on fine but then dims????
Hi there, I have the same monitor, but mine has a broken screen. It's probably the inverter chip, that makes your contrast bright.
Jan 03, 2009 | Westinghouse L2410NM 24 in. LCD TV
No power dell monitor e176fpc
do you get a power led on the monitor but no picture? then it is blown capacitors in the vga board inside the monitor
Dec 03, 2008 | Dell E176FPC Monitor
Sceptre X9G-NagaIV 19" LCD Monitor Logo
1,024 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
