Question about Olympus WS-100 Digital Voice Recorder
Problems caused by "improper device removal"
Yesterday, my WS-100 wouldn't turn on so I replaced the batteries. Today, when I plugged it into my Macbook Pro, the following message appeared:
"Device Removal: The device you removed was not properly put away. Data might have been lost or damaged. Before you unplug your device, you must first select its icon in the Finder and choose Eject from the File menu."
However, the computer then stops recognizing that anything is plugged into it and the screen on the DVR goes blank too. I tried unplugging it and putting the two pieces together with a new battery, but it still won't turn on.
What can I do? Is this reparable?
  • a-elahi Aug 20, 2008
    That makes sense, but I can't seem to find those files on my computer. Is there any way I can get them from somewhere else (perhaps another of the same recorder)? If not, is there any way to fix this problem? I think I may have accidentally deleted those files.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
The recorder has .dat files in each folder and must not be deleted. if you still have them on your computer, then you can transfer back to the recorder and the recorder should work fine
Posted on Aug 20, 2008
  • Randy Morton Aug 21, 2008
    do a search on your computer for recovery.dat.... that is one of the missing files.
    If you cant find it then you will need to send the recorder into the olympus repair to get the problem resolved
It charged to 100% yesterday And I plugged it in overnight And today it is not charging past 20% Please help me
-If the charger works then the battery has dead cell.
-replace new battery. You should be good to go like before.
Good Luck
Mai
Sep 25, 2015 | Computers & Internet
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
We have three sony MP3 walkmans 16g. The USB cables on all three devices will not load. I can use any other usb cable for any other device and it will work, just not on the mp3's. I have rebooted, changed...
I had a similar problem, mine wouldn’t turn on unless I plugged it in the computer and then it still wouldn’t work!
I found this on Sony’s trouble shooter -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
Battery must not be discharged 100%
If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
So I bought a USB adapter charger! Plugged it in and now it is working!
HOPE IT WORKS FOR YOU!
Jan 27, 2010 | Sony Network Walkman NWZ-S545 Digital...
1997 sable with 12000 miles electrical problems
earth cable from body to engine and battery to chassis ,clean the connections and fit an additional cable ,also clean and grease the battery terminal
Jan 25, 2010 | 1997 Mercury Sable
Sony Walkman connection problems
Cause:
Remedy:
May 15, 2009 | Sony Walkman NWZ-A828 Digital Media Player
My voice recorder won't turn on!!!
We had a similar problem (it wouldn't turn on), and it turned out that we hadn't taken off both layers of clear packaging from the batteries. It now works.
Jan 08, 2009 | Olympus WS-100 Digital Voice Recorder
Turn on problem
Some times, the charging cable from the laptop will not charge a fully depleted battery. If you have not already done so, try charging it using the wall charger that came with the phone.
Hope this works!
Aug 29, 2008 | Apple iPhone Smartphone
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Olympus WS-100 Digital Voice Recorder Logo
272 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
