Question about NAD Audio Players & Recorders
My L54 DVD Receiver is no longer showing any information in the Display area (Vacuum Flourescent Display). Could I please ask for your assistance in this matter. Thank You Wilma Coughlin wjcoughlin@rogers.cm
  • kirbymisty Jul 03, 2008
    Thank you you were most helpful. I will get it into Repair.
    Wilma
    President:
  • 624 Answers
These type of problems usually require some electronic troubleshooting. It is not a good idea to try it yourself unless you have some experience and understanding of electronic circuits. If you have none of these skills, you really should take it in to be serviced by a professional. The display going out is rarely ever a simple fix for anybody without the above mentioned skills. It can also be dangerous poking around inside these things. It does have 120 volts of A/C and could shock you very badly.
This NAD does not have any buttons to control the display illumination as some other types do, so there is no quick fix.
They normally have a 2 or 3 year warranty. If it is within that range since your purchase you really should take it in for a free repair.
Here is the contact information if you live in the U.S.
NAD Electronics of America
6 Merchant Street, Sharon
Massachusetts MA 02067
+ (1) 781 784 8586
+ (1) 781 784 8386 (fax)
Use this link to find a service center in your area if you live outside the U.S.
http://nadelectronics.com/distributors
I hope this was helpful to you
Dave
Posted on Jul 03, 2008
  • Dave DeGain
    Dave DeGain Jul 03, 2008
    So I get a "thanks for trying"? I guess you didn't know that this is a bad rating. Now my score gets pulled down for giving you some helpful information.
How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:
Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.
The unit will then boot up in factory default.
Henrik Pedersen
Jul 20, 2012 | NAD Audio Players & Recorders
Showing flourescent pink on display
Went to another site that offered commonly asked questions about product. Found the answer at a faster pace.
Jan 21, 2010 | Epson PowerLite S1 Plus Multimedia...
I need the dtv remote code for my memorex dvd/cd player
I work for Memorex tech support. Our number is 800-919-3647.
Unfortunately, Memorex TVs and DVD players can not be controlled by universal or cable remotes. If you need a replacement remote, please call Memorex's parts distributor, Fox International at 800-321-6993 to make the purchase. If they no longer have stock, try www.remotes.com.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 09, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Yamaha RX-770 Receiver display quit
there is a bulb inside the backlight on the lcd display.it is 12 volt and alot of manufacturers run it from the +- 15 volt preamp power supply,on the plus rail.when the bulb burns out it can activate the dc speaker protect,or some other 12 or 15 volt circuit..if it is a flourescent display that is a different problem.those run on 5 12 18 and -32 volts.there is also a 6 volt ac filament voltage.you need the schematic.
Jun 14, 2009 | Yamaha RX-770
HK AVR35 Receiver - Dolby Digital not displaying or working
If the display is showing as optical/PCM, then the input signal is in 2 Ch Stereo.
Try to change the signal from the source i.e. the DVD player, On the remote, go to audio and press repatedly , the audio would change from audio1, audio 2 .... and so on, depending upon how may have been recorded on the DVD. If the DVD is recorded in Dolby Digital, it may show the audio as Dolby Digital 5.1 on you monitor. Once this setting has been done, your Receiver should automatically detect it and show as Optical/Dolby digital.
Please let me know if you you solve your problem.
Mar 12, 2009 | Harman Kardon AVR 35 Receiver
Coby209
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Feb 18, 2008 | Coby DVD-209
Emachine startup problems
Good afternoon, nooks!
You an try taking it down to barebones and see what happens.
By bare bones, I mean to disassemble to the point that you only have the power supply, motherboard, and the display hooked up. At this point, if it doesn't come up farther than it does at present, you more than likely have a bad motherboard.
If it does show signs of life, start reconnecting one item at a time, (memory first) and try to power up after replacing each item or connector. If you replace/reconnect something and it no longer does anything, you have just located the part that is bringing your system down.
Using this approach, I have seen memory cards, hard disk drives, keyboards, mice, touchpads, floppies, cd readers all cause this type of problem.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Dec 10, 2007 | E-Machines eMachines Desktop PC
Yamaha Receiver RX-V670
Parts list and exploded diagram of yamaha rx-v850 found free here:
https://www.vancebaldwin.com/shop/research_new/YAM/RXV850.pdf
Enjoy. They can get the bulbs for $1.40...
Bsmt Dweller
Sep 07, 2007 | Audio Players & Recorders
Ge cordless 900 mhz home phone
What is "Bell" and "Cogeco"? Did you change phone line provider companies? If so, you would need to ask them if it's possible to change. You are getting the information they are sending you. I do not believe the information is being altered by your phone.
Jun 19, 2007 | GE 21028GE3 Cordless Phone
140 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
