Question about Asko Washing Machines
After swith on only drain pump is running. All lights are on. Will not respond to fault tracing program.
  • hlassner Jul 03, 2008
    Thanks it did not work.Iam up for a new board I think.
    Thanks again
    Hans
    Novelist:
  • 161 Answers
Try unplugging overnight. If it won't even fill or respond to any command it is probably a bad board or keypad. I have had this happen to me and after unplugging it seems ok for a few months. I have come home and found only the drain pump running before. This was hours after I started the washer.
Posted on Jul 03, 2008
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Water will not drain from Beko washing machine, (no power).
If there is no power it seems that the power supply to the control board has failed or the control board itself has failed. You need to trace the voltage to confirm before proceeding further.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Mar 08, 2013 | Washing Machines
My maytag neptune MAH6500 wont start. panel lights up but doesnt respond to any buttons,
Jan 23, 2013 | Maytag MAH6500 Neptune Front Loading...
Whilpool gu2300xt,wash cycle lights wont light,when i push start button goeswt calcell and drain and you can here drain pump then it shuts off
It is likely there is some fault with the float switch. Which means the dishwasher thinks it is overfilled with water and tries to empty out to protect itself. This is why the pump turns on as soon as you try to run the dishwasher. Refer diagram. You need to check if the float (12) spring is responding by pressing it down and checking if it comes up. Also level switch could be faulty.
Jan 12, 2013 | Whirlpool Gold 24" Tall Tub Built-In...
I have a SGV43A03GB Bosch dishwasher that has run perfectly for several years and now stopped. Essentially all the lights remain on, there is water in the pan (indeed it fills after having been emptied...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Also if the Inlet valve is staying OPEN and the drain pump is working as soon as the machine is switched on then it can be fault in the controller unit.
Jul 07, 2011 | Dishwashers
The dishwasher won't drain completely. Leaves a little water when finished.
If the heater element in your dishwasher is working correctly, and there is still water left in your dishwasher when the cycle completes, you may have a clogged drain pump (located beneath the dishwasher). You will need to remove the dishwasher and disconnect the drain pump hose to check for clogs. You may also need to remove the drain pump and check it for clogs or correct operation. If the drain pump is found to be bad, replace it, else clear the clog and try again. If you drain hose is going to a garbage disposal unit, check the hose connection and check inside the garbage disposal unit for a clog. You may also want to check the hoses for a clog under the sink if your dishwasher is connected this way.
Jul 02, 2011 | Dishwashers
Washer fills and washers btu won't drain or spin have already replaced the water/drain pump but still will not drain Model number is GLWS1339ESO
This applies to most washers:
Loss of power to a drain pump and /or drain valves can usually be traced to two main problem areas:
1. Faulty timer (aka rotary control) units
2. Discontinuity due to wire fatigue or loose connections.
Fault finding of #1 can be difficult, particularly if the person doing the fault finding does not have the necessary tools, and does not understand machine logic or the steps that create the whole.
Fault finding in the case of #2 is somewhat easier, since visual and/or manual inspection is a great aid. However, a multimeter is still an almost indispensable tool and allows easier fault-finding and diagnosis.
Feb 12, 2011 | Frigidaire Hardware & Accessories
I HAVE A GWLO8 WASHER ..DRAIN MOTOR SHORTED OUT ,BLEW FUSE . PUT IN NEW DRAIN MOTOR NOW WHEN I PLUG IN THE WASHER THE DRAIN MOTOR WILL NOT STOP RUNNING UNLESS I PULL THE PLUG. ALL THE PANEL LIGHTS RESPOND...
Hi Joe.Unfortunately if your drain pump shorted out and when you replaced it with a new one, it keeps draining, then the fault now is your MOTOR CONTROLLER.It became faulty when your pump shorted out.This happens sometimes with the Fisher and Paykel washers.Hope this helps and if you need further assistance then please reply and I can help you replace the CONTROLLER if you decide to change it.Just a note before you go and purchase a new controller ring your local FISHER and PAYKEL dealer and ask them if they can test your CONTROLLER for you,Just to be sure.I know my diagnosis of your fault is correct but I think we must cover all our bases.Looking forward to your reply.
Jul 31, 2010 | Fisher and Paykel Washing Machines
Windshield washers not working
I wouldn't worry about tracing the hose just yet, most likely it's a bad pump. Find the wire(s) going to the pump, usually on the bottom of the reservoir and connect a test light to a good ground. Then have someone try to 'squirt' the washer fluid while you touch the test light 'probe' to the pump's wire connector. If it lights but no fluid squirts, it's bad. They are cheap and usually very easy to replace. If it doesn't light there's a brake in the circuit somewhere. (bad fuse, bad connector, etc.) Good luck.
Jan 18, 2009 | 2005 Pontiac Vibe
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
